newbie questions
Old Dec 29, 2007 | 06:28 PM
mrdeere1959's Avatar
mrdeere1959
Default newbie questions
I here talk about pc, pcIII ,SERT what are these. Do I need it? I have a 08 ultra with 103 stage II. A little more power would nice as I'm pulling a hack. thanks Dale in Casper
Old Dec 29, 2007 | 06:31 PM
captjon37's Avatar
captjon37
Default RE: newbie questions
You don't need it but i am sure if you had it you would kick yourself for not getting it sooner.
Old Dec 29, 2007 | 06:40 PM
Bill918's Avatar
Bill918
The terms you are referring to are devices that change the mapping of your ECU, which controls fuel metering, air, spark advance. These devvices will often yield better results (performance) than having your dealer download a pre-programmed map. They also give you the ability to maximize the bikes performance by having the bike tuned on a dyno. The SERT is a HD device and is used to reprogram the ECU. The PCIII is made by Dynotech and piggybacks the ECU and stays onboard the bike. Search this forum, there is tons of info on these devices. Hope this helps.
Old Dec 29, 2007 | 06:43 PM
mrdeere1959
What would have the dealer done when the installed the 103 stageII?
Old Dec 29, 2007 | 07:09 PM
SoCal_Pappy's Avatar
SoCal_Pappy
If the Dealer did the Stage 2 - I sure you have something??? A download or a SERT - I would check your paperwork to see...
Kbore
Jul 5, 2009 05:16 PM
jsbridgew
May 16, 2008 05:19 PM
sedynaglide
May 12, 2008 08:37 AM
SlowPlay
13
Mar 9, 2008 09:05 AM
OPTPERF
Dec 13, 2006 10:08 PM
