I'm sure if you have the dealer install the SERT - They're going to run a dyno also to fine turn it.... NOT the cheapest way to go... But the SERT does work well...
What's the ball park $$$$ to have this done and is there anyone in the cocoa,fl area?
You don't need any of these unless you plan to change the pipes and the stock airbox. Some claim they have resolved the heat problem by adding a Power Commander or Fuel Pack without any other mods. IMHO, it is not worth spending any extra money for performance unless you make some adjustments that provide performance.
Probably worth your time to look around and decide if you want to do more than just add slip on mufflers before you commit to purchasing a fuel management system. From that point then you can decide if it is worth between 250.00 - 1000.00 bucks to add it and then decide which solution best fits the modifications you plan to make.
