Difference between 07 & 08 also ABS and non ABS forks?
I am looking at a set of powder coated forks off ebay, says it will fit 00 and up, I wanted to make sure that the new Brembo's and especially the ABS does not change anything on the forks. I have an 08 SG..
RE: Difference between 07 & 08 also ABS and non ABS forks?
My local dealer is using non 2008 forks on the 08 and just adding a spacer for the ABS models. That's what they told me when I asked about this same thing.
Duke,
Lowers are the same from the past previous years. My stock lowers had the 06 entire assembly part number on them and when I broke a nub I actually replaced with a lower from 02 or something like that. I also sent ya a couple of PM's reference the SE air cleaner
ORIGINAL: dawg
Duke,
Thanks for the responses, I really want to do the black forks on the scoot!
