Tour Pack Question? EDITED
Old Jan 13, 2008 | 08:25 PM
RED E GLIDE's Avatar
RED E GLIDE
Default RE: Another Tour Pack Question?
O.k. sorry for the delay.
My 05 manual shows the ground comes to the radio through the gray connector,
(at the back of the radio)pin 11and pin 19wire color for both isblack with a green stripe. They connect to ground at the upper tripple clamp. Any"open " in this wired connection and your radio will seek to ground through the antenna.
Old Jan 13, 2008 | 09:06 PM
sewerat's Avatar
sewerat
I just found this post again the 03 manual shows no connections to the radio as per grond thru the antennas but there is a blk with that mounts under the seat that connects to the main wire harness of the radio it would be in pin location 8
Old Jan 14, 2008 | 06:39 AM
Adam17's Avatar
Adam17
I'm sure this would be much easier if I just get a manual myself , but I will try t trace down with your description. Thanks for taking the time..
Old Jan 14, 2008 | 05:34 PM
Adam17's Avatar
Adam17
BIG THANKS to RED E GLIDE & SEWERAT for the help. Took off front fairing found ground wire disconnected, reconnented and radio works fine. I really like the look w/o tourpack while still having the option to put tour pack back on. Again thanks for the help guys. The conversion slowly begins--
Old Jan 14, 2008 | 05:43 PM
Wally's Avatar
Wally
Good.
Old Jan 14, 2008 | 06:11 PM
RED E GLIDE
Glad I could help!
Old Jan 14, 2008 | 07:00 PM
MarkThomas's Avatar
MarkThomas
Glad to hear it worked out...and I agree, an Electra would look great without the Tourpak (when not needed). A sort of modified Street Glide!
N2HARLEYS
2014-2024 Touring Models
Feb 1, 2017 09:01 PM
Lppring
Audio Systems
Aug 29, 2016 08:21 AM
Dallastx
Audio Systems
Mar 16, 2012 05:32 AM
woody0404
EVO
Oct 26, 2011 02:05 PM
HD Jake
Dec 28, 2006 02:14 PM
