Air Baffle
Old Jan 16, 2008 | 09:35 PM
cterrysgd's Avatar
cterrysgd
Default Air Baffle
Does this air baffle block air going to the motor? What air does it block from the rider? I'm just having trouble visualizing how air that goes between the forks will end up hitting the rider and not the motor if you don't have this installed?
http://www.harley-davidson.com/gma/g...bmLocale=en_US
Any thoughts?
Thanks!
Old Jan 16, 2008 | 09:40 PM
jringo's Avatar
jringo
Default RE: Air Baffle
Less air comes up around the tank, deflects air towards the motor. I run it year round.
Old Jan 16, 2008 | 09:43 PM
smknflms's Avatar
smknflms
..bought one..installed..rode 40 Interstate miles..removed and returned to dealer for return..didn't appear to do much, other than change airflow from lower face to a little higher and more pronounced on sides of my helmet..but a lot of people swear by them..might try one and see what it does. Five minute install, just be sure to run a 1/4-20 tap to chase paint from threads before install.
Later
Old Jan 16, 2008 | 09:48 PM
cterrysgd's Avatar
cterrysgd
So it keeps air from running off the tank and up your nose?
Old Jan 16, 2008 | 09:49 PM
rome304's Avatar
rome304
suppose to stop air from coming up under forks. like mine lot of chrome for 20 bucks.
Old Jan 17, 2008 | 12:02 AM
atexn4christ's Avatar
atexn4christ
I did not realize I had one till I bought one and went to put it on. I might take it off and see if there is a difference.
Old Jan 17, 2008 | 04:23 AM
relli's Avatar
relli
cuts air flow from below tank DIRECTS air to engine. my oil temp dropped 10 pls degrees with this simple install
Old Jan 17, 2008 | 05:13 AM
NoMistakes's Avatar
NoMistakes
Here's a close-up of the baffle on my RKC.
Old Jan 17, 2008 | 07:18 AM
navyman's Avatar
navyman
I put one on my Ultra, but can't tell any difference. Others swear by them.
Old Jan 17, 2008 | 07:32 AM
Uncle Peepers's Avatar
Uncle Peepers
This was a stock item until about 2002, I think. The idea was to deflect more air toward the engine to keep it cooler. Harley removed it but offered it as an option, ostensibly because while it helped cool the engine, it warmed the rider. Of course, hot riding discussion has now gone to a whole 'nother level.
