Throttle Cable adjustment question.
Old Jan 16, 2008 | 11:41 PM
WingIt's Avatar
WingIt
Default Throttle Cable adjustment question.
I changed my grips on my 07 RK and was adjusting my cables following the directions in the manual. Said to hold throttle open then tighten the throttle cable so the tab just contacts the wide open stop but snaps back to the idle position when you let go. Well I did this and the throttle won't snap back to idle, so I backed it off per the instuctions until it did but it puts me about a 1/4" form the stop. I guess my question is is this normal ? seems like I won't be getting full throttle. Hope this make sense ,sorry if I'm not using the right terms but I don't have the manual in front of me.
Thanks
Old Jan 16, 2008 | 11:48 PM
jringo's Avatar
jringo
Default RE: Throttle Cable adjustment question.
You need a little slack when the bars are straight. Throttle should have virtually no play when bars are turned all the way.
dragon78
Nov 13, 2019 10:25 PM
gonzosc1
General Topics/Tech Tips
Jan 16, 2016 08:24 AM
pheur
Aug 12, 2011 08:30 PM
Roadkingfatboy
Feb 18, 2010 08:22 AM
sharkeydude
Oct 12, 2007 08:33 PM
