exhaust flow on TC96B
Old Feb 16, 2011 | 11:23 AM
cowboybob56's Avatar
cowboybob56
Default ehaust flow
I am pulling this thread back from the dead as I have never seen an answer to this question. Especially sinse I too feel a stronger pressure on the jiffy stand side than I do on the air cleaner side.
Old Feb 16, 2011 | 11:33 AM
bmaier's Avatar
bmaier
Originally Posted by twincam47
first off the TC96B engine is a softail engine=internally balanced
My first thoughts when I read the title, why post in the touring section? Then I saw it was a RK; not a 96B motor
Old Feb 16, 2011 | 11:36 AM
bmaier's Avatar
bmaier
Interesting, with the factory 2-1-2 headpipe the right side (air cleaner side) should have more flow
Old Feb 16, 2011 | 12:18 PM
shore's Avatar
shore
My stock 07 was harder out the right side and the right side has the clogged up emmisions stuff in it. The left side pipe is just a small plate baffle. I took a bar and rammed it through the left side muffler and then swapped it to the right side...it was really night and day then.
The stock exhaust goes like this:
front header..all right side.
rear header....mostly right pipe and some left. The crossover pipe greatly favors the right side exit.
I put a fullsac conversion on(simple) and both are even.
Old Feb 16, 2011 | 03:50 PM
cowboybob56
Default Exhaust flow
I will probably not be visiting my local stealer for a while as I am no longer under warranty. I was hoping for a definitive answer from the rider/experts in the know. I don't think they could be backwards as the dimples for the left side right side are where they are supposed to be. Now this is stock exhaust I am inquiring about. Or.......I could go ahead and order a set of the recored super-flows and end the issue all together. I am curious though, aren't you?
zigzag930
2014-2024 Touring Models
Jul 23, 2016 05:40 PM
Roadwarrior1
Exhaust System Topics
Dec 2, 2012 05:54 PM
1stGlide
Jun 25, 2011 06:28 PM
TerryB
Nov 29, 2007 07:41 AM
skykingFLHTCU
May 15, 2007 12:16 PM
