Help; Front wheel spacer question????
Old Jan 24, 2008 | 08:08 PM
sjnorton's Avatar
sjnorton
Default Help; Front wheel spacer question????
I just got my new PM 21inch wheel and when I took the old wheel off I did not notice that the two spacers are different widths. I put the new wheel on and now it wont spin freely. I swapped the spacers around and now it seems to spin a little better. One spacer does say L and the other R; is this sitting on the bike or standing in front of it????One more question isit possible that the bake pads need to set in a little. I don'twant them to heat up and cause the front wheel to lock up....... any help is appreciated
Old Jan 24, 2008 | 08:10 PM
mopar7's Avatar
mopar7
Default RE: Help; Front wheel spacer question????
From sitting on the bike.
Old Jan 24, 2008 | 08:12 PM
dawg's Avatar
dawg
left is primary side, right is tranny side so sitting on it
Old Jan 24, 2008 | 08:19 PM
sjnorton's Avatar
sjnorton
Thanks; it spins a little better but still not freely[>:]is this a problem or will it set it if I ride it???
relli's Avatar
relli
FYI- left and right is ALWAYS considered to be from "behind the steering wheel/handle bars " on any vehicle.
i noted in the manual that the left side frt wheel spacer on my FLHTC had 3 notches on one side that were supposed to be on the bearing side. yet it was installed with the notches outboard toward the axle nutwhen i took it apart.what is the purpose of this and could it have caused any damage???
Old Jan 24, 2008 | 08:25 PM
dawg's Avatar
dawg
ORIGINAL: relli
My manual states that's the way they're supposed to be
Old Jan 24, 2008 | 08:29 PM
sjnorton's Avatar
sjnorton
what about the spinning; am I going to crash?
Old Jan 24, 2008 | 08:37 PM
dawg's Avatar
dawg
ORIGINAL: sjnorton
It's normal to have some drag, depends on how much you have. Try a buds bike to see if it is about the same.
Old Jan 24, 2008 | 08:54 PM
relli's Avatar
relli
ORIGINAL: dawg
ORIGINAL: relli
unless ive read it wrong several times mine says with the 3 notches facing the bearing.ill check it tomorrow again.
Old Jan 24, 2008 | 09:18 PM
Biggzed's Avatar
Biggzed
Is your rotor centered in the brake pads? This could be what is causing you "binding". You might need to look at shiming the calipers and/or adjusting the wheel spacing with different length spacers. I had to on mine. The PM hub could be slightly wider or narrower than a stock hub. Measure them both if you can.
