Doherty Power Pacc - Install How To
Old Jan 26, 2008 | 09:57 PM
Dalton's Avatar
Dalton
Default Doherty Power Pacc - Install How To
I decided to go with the Doherty Power Pacc and Power Vents on the new engine. The quality of the parts are excellent and the machine work of the billet backing plate, velocity stack and cover is show quality. Doherty claims up to a 10hp increase is possible, but even if the gain is not real, I would have installed this anyway, just for the looks. Below is a narrative and some pictures of the install. Total job was less than a half hour to complete.
These are the parts that come with the kit.
After removal of the original air cleaner assembly, you mount the Power Vents to the heads using the supplied breather bolts and a nylon washer on each side of the Power Vent. The Power vents have one way valves to let crankcase pressure out, but do not let air back in to the engine top end. You can run hoses from the bottom of the Power Vents to below the bike or leave them as is. I chose not to run th ehoses at this time.
Next, attach the backing plate to the throttle body using the supplied allen screws and gasket.
Attach the billet backing plate to the breather bolt using supplied allen head bolts making a nice firm foundation for the breather assembly. You can see the quality of the billet work and polishing. Thats me behind the camera in the reflection.
Install the o-ring (lightly oiled) around the velocity stack, then press into place into the backing plate. There is a good tight seal. The inner diameter of the velocity stack is a perfect match for the 50mm throttle body, but will work on other sizes too.
Install the filter element and inner cover using the three screws with a dab of blue locktite on each screw.
Install the Billet Cover to complete the job.
A good looking air filter assembly that flows well.
Old Jan 26, 2008 | 10:00 PM
mattman22033's Avatar
mattman22033
Default RE: Doherty Power Pacc - Install How To
I have one of these on my Fat Boy and you are correct the quality is excellent.
Old Jan 26, 2008 | 11:08 PM
mtclassic's Avatar
mtclassic
If you don't run the hose on the bottom of the power vents what happens to the blow by?Do the power vents contain the oil or does it just run out the bottom. I am trying to order one but most places are out of them. My main reason for wanting one is to keep the blow by out of my combustion chamber.
Old Jan 26, 2008 | 11:23 PM
Harleypingman's Avatar
Harleypingman
Great post, Guy--I agree; whether it's good for any performance improvement, it's a beautiful piece.
Old Jan 26, 2008 | 11:45 PM
Dalton's Avatar
Dalton
ORIGINAL: mtclassic
If you have a lot of blow by you will need to run the lines. I am experimenting with the TP Engineering rocker boxes that have a new internal design to separate the oil from the air. If the engine is tight enough and the boxes work the way they are designed, I should not notice any oil , or little if any.The Power Vents are not "canisters" to hold oil, they indeed are one way vents. Even on a stock engine, the amount of blow by might be little enough that the vent lines may become optional, depending if you want to wipe the occaisional drip of oil off the bottom of them or run the lines to dissipate the oil under the bike.
If everyone is out of them, you may want to give Shooter64 (Bart) a shout on this forum, or you can order them directly from Doherty.
Old Jan 27, 2008 | 02:21 AM
Ram's Avatar
Ram
Great looking setup and how-to. I like the clean look and the velocity stack looks like its going to help with air induction.
Thanks for sharing.
Old Jan 27, 2008 | 02:28 AM
PapaTravis's Avatar
PapaTravis
Looks sharp... that cover is screaming for some custom engraving, though, LOL...
Old Jan 27, 2008 | 02:52 AM
Ram's Avatar
Ram
Guy, just wondering what the two holes inside the backing plate that have the "blue" showing in behind the holes? They are sitting at 3 and 9 o'clock! Obviouly inside the filtered area and would they be for something to be attached from the rear of the plate? Like hoses or something?
Old Jan 27, 2008 | 07:33 AM
SSJ's Avatar
SSJ
ORIGINAL: Ram
Excellent photos on the install! the blue holes are knock out plugs IF you decide the run the tubes from the power vents into the back of the plate (which I did on mine) all the parts are there to install it this way, the instructions say performance is not affected either way.
I really like my PowerPacc not really sure what power gain I achieved as I added a Terminal Velocity tuner at the same time, but you feel from the ride substantial power and torque gain and it sounded a lot better with the Supertrapp SE slip on's I already had. Every independent test article I read about the PowerPacc raved about the dyna proved power gain best on the market.
Only problem I had on the install is I had to re tap the back cylinder thread to get the bolt secured all the way in, felt like very shallow threads or a little stripped, the original came out very easy like the front? they supply a lot of extra washers for this purpose but I didn't want 15 washers on the bolt as it would turn about one and half turns then stop.
Old Jan 27, 2008 | 08:42 AM
Ram's Avatar
Ram
ORIGINAL: SSJ
ORIGINAL: Ram
Thanks, I kind of suspected that in that location but have never seen them before and didn't really know!
