CAMS
Old Jan 27, 2008 | 10:35 AM
Older Guy's Avatar
Older Guy
Default CAMS
I will be picking up my 08 SG in a week or two, Having stage 1 done , thinking of having 510 cams done also. I do not intend to use any type of tuner. Just stage 1 and rush slipons. would now be the time to change over to the cam drive?
Bandit
Old Jan 27, 2008 | 11:22 AM
Zimbob's Avatar
Zimbob
Default RE: CAMS
Why not just ride for a while and think about it. You may be opting for the sert before long. Do the cams later, get a feel for your scoot first, but that's jusy my opinion, and we all know what an opinion is.
Old Jan 27, 2008 | 12:28 PM
nvsteve's Avatar
nvsteve
Default RE: CAMS
If you're going to upgrade cams you will need a tuner so why waste the money on the stage 1 download?
Also, I'd do some checking to see how the upgraded cam chains and pads are holding up on the 06 Dynas and 07 bikes. Might not be necessary to go gear drive.
Old Jan 27, 2008 | 12:50 PM
maineultraclassic's Avatar
maineultraclassic
Default RE: CAMS
ORIGINAL: BANDIT
Bandit
Your '08 is already running so lean it wants to burn up stock, now if you do an air cleaner, exhaust, and cams.........you better wear a fire suit when you ride that thing.......it will burn up in no time.
Save your money and run away from the dealer with the bike stock, then go aftermarket parts for the power upgrades you want to do. It will work out better in the end and give you better performance.
Steve
Old Jan 27, 2008 | 02:59 PM
Older Guy's Avatar
Older Guy
Default RE: CAMS
This is my 5th Harley, I have always had stage 2 big bore kits in all of them. Never needed a race tuner in any of them . This time I just felt the bike has enough power for my type of riding. Just thought about putting cams in now instead of later. I think I will take your advice and see if they are realy needed later.
Thanks for the thoughts
Bandit
Old Jan 27, 2008 | 04:06 PM
Timex's Avatar
Timex
Default RE: CAMS
Good advice. Wait on cams till it's broken in. You'll for sure be able to see an improvment with the new camsif you can wait tillthen.
ORIGINAL: maineultraclassic
ORIGINAL: BANDIT
Bandit
Steve
Old Jan 27, 2008 | 04:14 PM
GliderXXX's Avatar
GliderXXX
Default RE: CAMS
ORIGINAL: BANDIT
Bandit
Good idea.
Old Jan 27, 2008 | 05:15 PM
Forget About It's Avatar
Forget About It
Default RE: CAMS
bandit i have a set of 510 gear drive cams and gears oil block off plates for the cam plate for an 08 that i took out off my 08 road glide for sale they only have 200 miles on the i took them out becauser i have a 107" 10.5 to 1 compresson motor and the 510s werent enough cam for that moto have headqaurters 575 cams in it now i will SELL you my 510 kit for 400 bucks they retail for 700
Old Jan 27, 2008 | 06:53 PM
rick180's Avatar
rick180
Default RE: CAMS
Dave I sent you a PM.
HD9358
Engine Mechanical Topics
Nov 1, 2017 04:23 PM
sskimber
May 30, 2016 10:17 AM
rob0225
Nov 15, 2014 06:19 PM
Colin1966
Sep 20, 2012 09:09 PM
fjoh
Oct 27, 2011 09:13 AM
