Lubing cables
Old Feb 7, 2008 | 02:50 PM
04 rkcrr's Avatar
04 rkcrr
Default Lubing cables
What kind or brand do you recomend for lubing throttle and clutch cable. I dont think any type of penetrating oil should be used but I could be wrong.
Old Feb 7, 2008 | 02:54 PM
eglidetrike1's Avatar
eglidetrike1
Default RE: Lubing cables
Just use something made specific for cables.
Old Feb 7, 2008 | 03:08 PM
Jinks's Avatar
Jinks
Bike Aid, available at motorcycle & bicycle shops everywhere.
Old Feb 7, 2008 | 03:17 PM
twincam47's Avatar
twincam47
don't use anything graphite because of Teflon coated cables and Teflon lined Cable Housings...
Use a thinoil based product preferably containing silicone or teflon.
Old Feb 7, 2008 | 03:20 PM
Headwolf's Avatar
Headwolf
I have an 05 Dyna Superglide Custom and was wondering when is a usual length of time when you need to lube cables. Can you tell it needs lubed or is it just do it every year type of thing. The reason I ask is I had the easy clutch kit put in about a year ago and the difference was amazing. Now though, it doesn't seem so "easy". It could be I either got used to it or it is time to lube. Since it degrades gradually you don't really notice it. Any advice as to when to lube would be appreciated. Tricks and tips on lubing would help also. Thanks
Old Feb 7, 2008 | 03:23 PM
electaRICK's Avatar
electaRICK
I use a cable luber,, which allows you to spary into the cable housing,,, I use silacone.
while doing this take your clutch lever right off and clean every single piece, and part.
you'll notice a big diff!
Old Feb 7, 2008 | 03:24 PM
russl179's Avatar
russl179
Do any of our HD maintenances include lubing of the cables?
NICK56's Avatar
NICK56
CABLE LIFE OR DRY SLIDE..(ALSO CALLED BIKE AID)
GET IT AT MOST MCY DEALERS ..,USED IT FOR 20 + YEARS
Old Feb 7, 2008 | 05:05 PM
Big Peter's Avatar
Big Peter
ORIGINAL: Headwolf
Here you go www.expertvillage.com/video-series/1207_motorcycle-maintenance.htm
Greetz,
Peter
Old Feb 7, 2008 | 05:08 PM
mtairy biker's Avatar
mtairy biker
i like dry slide it comes with a neddle to put it down the cable
