2 into 1 vs. Tru Dual
Old Jan 22, 2006 | 06:28 PM
OG_electra_glide's Avatar
OG_electra_glide
Default RE: 2 into 1 vs. Tru Dual
I swear I just saw an advertisement somewhere for a 2:1 exhaust with a 2nd "dummy" pipe for the other side of the bike. But I agree, if it's an improvement in the 1-2k rpm range, where would one realistically see that improvement? You'd be going 35 in 5th I guess, at less than 20% throttle.
Old Jan 22, 2006 | 07:17 PM
Slider's Avatar
Slider
I know D&D makes what they call a "Ghost Pipe" for dressers. It is about $250-300.
ORIGINAL: OG_electra_glide
Old May 23, 2011 | 01:01 PM
FLHTCI 02's Avatar
FLHTCI 02
Stage II
Default SE to True Duals
Be prepared with a SERT and a good Dyno run. I made the switch and my bike ran really bad until I went to the SERT and it was on the Dyno for a while. Now with my V&H True Duals and bike tuned right they are the best investment I've made. Put 103 behind them and they are loud and sound fantastic...
Originally Posted by BaggerDave
Has anyone here made the switch from SE Slip-ons to True Dual head pipes?
If so, what difference did you notice if any?
Old May 23, 2011 | 02:55 PM
qtrracer's Avatar
qtrracer
A properly sized 2-1, header tube length and diameter for the flow requirements of your engine, with the correct angle merge collector, will work better than any true dual made at any rpm.
Old May 23, 2011 | 03:41 PM
Jack Straw's Avatar
Jack Straw
I'll chime in.....
All of my life I hated the look of 2-1's and especially on baggers. But, it's grown on me after I purchased this last bike which came stock 2-1. So, that's the look I kept when I upgraded. I like it. And from the numbers I've seen, you're getting good numbers at the bottom and top ends.
Old May 23, 2011 | 04:00 PM
tgspencer56's Avatar
tgspencer56
Can't beat the D&D. Add the ghost pipe if you like the looks of duals.
Old May 23, 2011 | 06:40 PM
coolerman69's Avatar
coolerman69
I did on my sig bike. The difference is goin from bein the slowest bike in the pack to beatin stock 103s. I had a 2into1 and you definately notice more off-idle power. But unless you have a riding deficiency and tend to fall over at stoplights true duals are the way to go. IMO
Old May 23, 2011 | 06:52 PM
Mike's Avatar
Mike
Too many variables to make a generalization. Properly designed 2-1 systems with a merge collector (like a fatcat or propipe) will generally make a bit more at the lower rpms, due to increased exhaust scavenging. As rpms and exhaust gas speeds rise, the scavenging effect from the opposite cylinder has less of an effect, and overall exhaust volume becomes more important, and that's where the good TD systems start to gain an advantage. The tune is crucial. The best exhaust in the world won't overcome a poor tune, but a good tune can compensate for all kinds of exhaust variations.
Your definition of best performing might be different than another guys. Some want the most power, peak torque and hp, others focus more on early torque production.
Here's a chart showing two identical bikes, exactly the same except for the exhaust. The one with the fatcat 2-1 has an earlier torque curve, the one with the Rinehart TDs has higher overall numbers. Running around town, the fatcat bike will feel a little snappier, but in a race, the one with the TDs would likely pull away.
Here's another chart comparing the fatcat with the Rinehart TDs. Similar looking curves. Again, up to about 3K rpms, the fatcat comes on earlier, but the Rineharts post higher numbers. Some guys want the early torque curve and don't care about overall numbers, others want the most power they can get.
Old May 23, 2011 | 07:02 PM
'05Train's Avatar
'05Train
This.
I've recently changed from a Fatcat to a 2:1:2. There's no doubt in my mind that the Fatcat makes more power everywhere. TDs are going to be an even larger difference, especially down low.
Boogaloodude, any tuner worth his salt can tune away that horrendous torque dip on the Fatcat.
Old May 23, 2011 | 07:12 PM
evofloyd's Avatar
evofloyd
looks suck, but thunderheaders {10 more ponies} and potato-potato
