Does anybody out there know what happened to the E-Z Flow company. They made quick detachable crossovers for the fuel tank that did not leak making it easy to remove your tank. They were located at 10331 Elmdale Drive Spring Valley , California. Or do you know of any dealers taht may have an SS-2. We need one for an FLHT we are doing.
I'm really bummed that they are gone too. I had several sets of them They sure made life easier.
I recently found someone selling very similar quick disconnect fittings to splice into a lenght of 5/16" fuel line. THe add is as follows:
________________________________________ The Details:
[ul][*]Very High QualityâŚPrecision Look and Feel[*]Bright Chrome Appearing Nickel Plated Brass[*]Premium Engineered and Manufactured[*]Equipped with Genuine VITONÂŽ Seals for Durability[*]Very CompactâŚless than 5/8" diameter and 2" Installed Length[*]Overall Length is just under 3 Âź"[*]Double ShutoffsâŚDisconnect and Remove Tank with Fuel Remaining[*]OR⌠Easily Drain Tank of Fuel (using a second disconnect set)[*]One Handed Operation[*]No Button to PushâŚSimply Pull Back the Collar[*]Audible "Click" When Connecting to Assure a Good Seal[*]Free Flowing when Connected to Enable Proper Fuel Balance[*]Time, Frustration and Fuel Spill SaverâŚEnhances Safety[*]Pressure rated at 500 PSI[*]Temperature rated at 400Âş F[b][*]High Quality, Properly Sized Clamps Included [/ul]
Technical Description: Both the male and female components are fitted with a valve utilizing VITONÂŽ seals. When connected, both valves are opened, guaranteeing full flow. The valves close when disconnected, which prevents the fuel from leaking. A high quality coupling with extremely compact dimensions. Single handed operation, high flow rate when connected, secure shutoff when disconnected. VITONÂŽ seals have extremely high resistance to gasoline. Buna-N seals do not.
[font="geneva, arial, sans-serif"][size=2]Prices are the same
I am a Bikers Choice Dealer and they haven't had them since '05, they were in the '06 catalog but were unavailable. Thanks for trying and the quick response.
