run turn brake
Old Feb 18, 2008 | 11:57 AM
1ADAM12's Avatar
1ADAM12
Default run turn brake
Hey guys im on the fence about the run turn brake light module for the rear,yeah or neah........
bikergeoff's Avatar
bikergeoff
Default RE: run turn brake
Do it!
Old Feb 18, 2008 | 12:08 PM
backnasaddle's Avatar
backnasaddle
Yep, Do it. I have the Kuryakyn with brake light pulse feature (flashes 3 times when brake applied). It's plug & play. Very easy to install. About $70.00-75.00. Don't forget to change over to red turn signal lenses if you set up the turn signals to act as full timerunning lights (which this kit does). The kit also comes with a load equalized if you want to go LED, but I stayed with my regular incandescent set up. Retains my 4-way flasher capability, too. You can also go big chingand change out tail andlight bar completely to full customLED run/brake/turn, but I didn't want to go the $$$. It's spendy.
Garemlin's Avatar
Garemlin
Yup. More visibility is a good thing. Run some LED clusters for even more visibility.
Old Feb 18, 2008 | 12:13 PM
YodaddyKeith's Avatar
YodaddyKeith
DO IT!
Takes 5 minutes.....Plug n Play.
The HD version is 54 bucks and comes with lenses.
Old Feb 18, 2008 | 12:21 PM
SamStone's Avatar
SamStone
ORIGINAL: backnasaddle
Can the Kuryakyn be set up so the signals are not running lights but come on and flash when the brakes are applied? I don't like the idea of the signals being running lights. You get more attention, when hitting brakes, if extra lights light up than if the lights just get brighter.
Old Feb 18, 2008 | 12:31 PM
soos's Avatar
soos
It is an excellent idea, except that the HD unit does have a flaw which I and others do agree on. The brightness of the running mode light is just fine, but the increase in brightness of the brake mode from running mode is barely noticable when you do hit the brakes. I have and prefer the older version that was just a brake light conversion so that when I applied my brakes my directionals went from off to bright stop. I wanted a very noticable application.
A few months back an HDF member posted a modification to the newer HD unit module that reverted it back to the style I have and just described above. I can'r recall the members name, but I do know that member "robandlyn" contributed to that thread by providing a color schematic for the mod.
Old Feb 18, 2008 | 12:38 PM
EdwardK's Avatar
EdwardK
The HD run/turn/brake can be hard to tell if the brakes are on or not. I had one and there just isn't enough difference in intensity for me. Yes, more running lights are good, butifthe guy behind you isn't paying attention, he may not realize you hit the brake.I ride in the city in stop and go traffic. I want to make sure they see my brake lights come on.
Look up a company called Biketronics. They offer several variations so you can pick one that suits your wants. I run what they call their Tailstopper.Turn signals operate as brake and turn but notrunning. One lightrunning. Three lights on for brake. If your behind me, there's no doubtthat I hit the brake. Just remember to change the lense to red.
Old Feb 18, 2008 | 12:45 PM
stukes_md's Avatar
stukes_md
SamStone,
This may be true if you keep the stock running lights. I have the Kury LED Panacea tailight and LED turn signals. I use the turn signals as running lights and there is a considerable difference in the running mode and turn signal/ brake light mode. Add the flashing feature of the lights and it does attract attention. Other riders that are behind me comment about how the system is bright and eye catching.
Old Feb 18, 2008 | 12:49 PM
GTK's Avatar
GTK
Its better to do it than wish you had
