Tour Pack with Advanced Amplifier Q..?
Old Jan 24, 2006 | 09:16 PM
Cache's Avatar
Cache
Default Tour Pack with Advanced Amplifier Q..?
I know I heard it said that with the Advanced Amplifier located underneath the tour pack,-'06 U/C that the tour pack is no longer adjustable.
My question is......Can you have the tour pack adjusted to the rear most position first, then attach the advanced amplifier? Can the connection still be made with little difficulty?
My ole lady needs some more room back there. I can't mention a diet either.
Thanks.
Old Jan 24, 2006 | 09:58 PM
MACK's Avatar
MACK
Default RE: Tour Pack with Advanced Amplifier Q..?
you have my sympathy. I think you will be ok. only problem will be if the harness is too short. .If thats the case you can splice in extra lenftg. Just make sure you solder the wires and use the hard plastic melt on connectors to insure a good tight fit connection.
Old Jan 24, 2006 | 10:42 PM
Mountainkowboy's Avatar
Mountainkowboy
The tourpack on my 03 isnt adjustable either and I also have the advanced audio system. I am going to use the Kyriakin (spelling) relocator and make a new mount/spacer for the amplifier. It adds 2" of room to the back seat.
Old Nov 8, 2008 | 06:25 AM
sportsterleroy's Avatar
sportsterleroy
From: South euclid ohio-east side of Cleveland Ohio
Any thoughts on this setup with a detachable rack newer smaller style? And with the plug on the harness fit thru the small opening of the detachable rack?
thanks leroy
SWThomas
Jan 29, 2015 08:09 PM
monumaker
Jan 11, 2011 10:19 AM
shortleg
May 29, 2008 04:17 PM
zook1065
Jul 11, 2006 10:53 PM
