PULLED PLUGS - WHAT DO YOU THINK?
Old Feb 20, 2008 | 06:12 PM
profinish's Avatar
profinish
Default PULLED PLUGS - WHAT DO YOU THINK?
I just pulled the plugs off my '07 RG with 800 miles. I rode the bike stock for 100 miles, then put the AN Big Sucker Stage 2 and rode for 700 miles. Here are what the plugs look like after 800 miles... what do you think?
I just ordered my exhaust (V&H slipons) and working on the fuel pak now... I may run the new exhaust with the current a/c for a couple hundred miles before I can afford the fuel management system. I'm sure it won't be a problem, just wanted to know how lean these plugs look.
BTW... if you don't know how to read plugs, please don't comment
Front Plug
Rear Plug
Old Feb 20, 2008 | 06:19 PM
electaRICK's Avatar
electaRICK
Default RE: PULLED PLUGS - WHAT DO YOU THINK?
pro,,,, no expert on todays HD's,,, but when I showed them my 07 plugs that looked like that,
I was told thats acceptable for todays bikes,,,, I had a hard time swallowing that,,,,
Its gone now anyways!
Old Feb 20, 2008 | 06:37 PM
Ram's Avatar
Ram
Temp looks ok, they maybe a little lean but not showing any signs of buring up anything.. need more run time to show anything conclusive. Its good that they are clean, better then all clogged up.
Old Feb 20, 2008 | 06:45 PM
mrsr71's Avatar
mrsr71
Looks a tad lean - #23
Old Feb 20, 2008 | 06:57 PM
2008FLHP's Avatar
2008FLHP
nice chart--thanks--where'd ya find it?
Old Feb 20, 2008 | 07:50 PM
El Pesado's Avatar
El Pesado
Looks slightly lean to me but most likely ok,as long as eng temps arent excessive. Slightly tan or pink color on insulator would be ideal.
Old Feb 20, 2008 | 07:56 PM
SoCal_Pappy's Avatar
SoCal_Pappy
Lookin on the Lean Side.... But then it's a '07 EPA Lean\HOT- Putt - Really shouldn't be running a Air Kit with out the Fuel Management System - Running lean can pitt the head of the pistons and can(see it) burn a hole\s into it....
Old Feb 20, 2008 | 08:48 PM
SteveO's Avatar
SteveO
Plugs are normal. Color is fine for todays fuels and F/A ratios, and there is no oil splashing. Looks like your engine set up is working fine.
Hope this helps.
Steve
Owner
The Dyno Room
Oct 9, 2017 05:54 PM
anothernewb
General Topics/Tech Tips
Apr 25, 2016 05:02 PM
criyi
Jun 27, 2012 10:28 PM
inswva
Oct 22, 2010 07:20 PM
Arizona
Exhaust System Topics
Feb 24, 2007 07:42 PM
