Fairing Help!!!fiberglass vs abs plastic
Old Feb 22, 2008 | 10:55 AM
JTE2518's Avatar
JTE2518
Default Fairing Help!!!fiberglass vs abs plastic
Lookingfor an aftermarket fairing and need some help. Found one from wide open custom plastics,
question, is plastic as good as fiberglass. and would you buy one bare and put your own system in it.
http://WIDEOPENCUSTOM.COM just need help dont want to spend $1100.00 on a fairing,paint and a radio,just to find out plastic sucks..
Old Feb 22, 2008 | 11:10 AM
89FLHT's Avatar
89FLHT
Default RE: Fairing Help!!!fiberglass vs abs plastic
The outer fairing shell on all 'glides is plastic from the factory along with the side panels and the Hard Bags... So it definitly works as a material to use or else the factory would be using 'glass.
Aftermarket Fiberglass fairings are typically heavier than the OEM plastic and there are different methods of building glass fairings that make some stronger than others. As far as buying an aftermarketbare plastic one and putting your own tunes in it, I was able to easily do it with the old OEM plastic inner and outer fairing, do all the repairs and get it all painted, so it would not be a show stopper to me just because it was plastic.
Old Jul 7, 2015 | 02:37 PM
flhs93's Avatar
flhs93
6th Gear
Wanted to know how the fairing from Wide Open Customs worked out. I have a '93 FLHS that I'm looking to do the same.
Old Jul 7, 2015 | 03:01 PM
revelator2's Avatar
revelator2
My personal 2 cents is that I will always buy a quality fiberglass piece over ABS plastic. The key being a quality made fairing. I have used two different fairings and have good success. The latest one is from Recklessmotorcycles.com It is a very well made product. The main reason I will buy fiberglass is simply because you can repair it and you cannot repair the ABS. Hope that helps you!
Old Jul 7, 2015 | 10:05 PM
Neggy ZRXOA 5248's Avatar
Neggy ZRXOA 5248
the post above me nailed it, if you ever need to repair a crack, deep scratch, etc, it is easier to repair fiberglass than ABS, not that it can't be fixed, it can, but very few people know how to do it.
HD has been making stuff out of ABS for well over a decade now, it is easier for them to do injection molding than laying out glass and gel coating/painting
it is not a bad material, I have been working with it for 40 years now, but you are not fixing it without solvent, heat
or ultrasonic welding
Old Jul 9, 2015 | 10:33 AM
flhs93's Avatar
flhs93
6th Gear
revelator2 and Neggy ZRXOA - thanks for the feedback. I checked out Reckless Motorcycles on the fairings for my ride. Unfortunately the '93 FLHS has the "breadbox" instrument cluster which makes it difficult to retro fit. Also trying to find an FLHT fairing from the mid to late 80's, as that would also work. If you hear of anything drop me a line. Thanks
Old Jul 10, 2015 | 06:45 AM
deltafred's Avatar
deltafred
I really do not have an opinion one way or the other. However, I have a http://woodysfairings.com/ and I cannot be more satisfied with the end product or customer service, which is made out of fiberglass. Glenn is a great guy to work with!
Old Jul 20, 2015 | 12:28 PM
flhs93's Avatar
flhs93
6th Gear
Hi deltafred, thanks for the input on woodys fairings, I appreciate it.
Old Jul 20, 2015 | 07:42 PM
Highwayman-AL's Avatar
Highwayman-AL
I damaged my original fairing, and I thought the OEM's were too much. I found one on Amazon that advertises Fiberglass reinforced ABS. Cost about $200.00 and was in vivid black same as my bike.
Since getting it I had it wrapped, replaced the brass inserts from Harley with the screw in type and installed speakers and amp, after changing my handle bars then the fairing. Fit like OEM, has held up very well, and no gaps, or squeaks and can't tell the difference.
cprhed
Feb 25, 2019 06:19 PM
jackinthebox
Jan 26, 2014 07:30 PM
TOMMY M
Jul 5, 2012 05:24 AM
Fxstsb6
Jun 10, 2012 10:39 PM
supercub12
Aug 15, 2011 08:34 PM
