Mileage on a back tire
Old Feb 24, 2008 | 07:13 AM
jaystone's Avatar
jaystone
Default RE: Mileage on a back tire
Really depends on what kind of roads you ride on and the heat will really wear them quickly too. I got about 8000 on my stock Dunlop and that on a Wide Glide mostly ride by myself.
scofield333's Avatar
scofield333
I got about 9k out of mine on a R/G..mostly 2 up. Could have maybe got 10k or 11k but didn't want to chance it with the wife and long trips....
Old Feb 24, 2008 | 07:23 AM
tdaffner's Avatar
tdaffner
I get about 13k on Avg. Just like others in this post, I tend to change both the front and rear at the same time. Costs a little more, but nothing beats that new rubber smell
Old Feb 24, 2008 | 07:31 AM
1flhtk4me's Avatar
1flhtk4me
I replaced the stock rear dunlop at 15800.Most of the miles were solo.
I think there are a few factors involed with tire life.Air pressure,road surface,throttle,braking,etc-.
Another thing to consider is that the tire compound could vary with the same tire.
Old Feb 24, 2008 | 07:40 AM
StonerGlide's Avatar
StonerGlide
I got just under 9k out of rear but could have probably gone 1500-2000 more. Replaced the rear as I had the IDS installed, made sense to do at same time.
Majority of riding is two up and half of that is loaded up, not hard on throttle.
Old Feb 24, 2008 | 07:42 AM
Arizona's Avatar
Arizona
My last rear Dunlop had 16,700 on it. I ride mostly solo and long distance freeway here in So Cal. I'm easy on the throttle and generally just cruise when riding.
How hard you are on the throttle, roadway surfaces where you ride, also how much you use the rear brake are all factors. Two-up riding will make a difference also.
Old Feb 24, 2008 | 08:24 AM
maineultraclassic's Avatar
maineultraclassic
12500 on my first rear tire
13000 on my second rear tire
Both were Dunlop D402, and the third one on there now is also.
Steve
Old Feb 24, 2008 | 08:49 AM
mchildree's Avatar
mchildree
Well, I see two factors that might have contributed to the short life...it does stay pretty hot around here most of the year, and the roads are in a constant state of construction. I'm really good about keeping the PSI right. Maybe I'll get a little more life outta the next one.
Old Feb 24, 2008 | 09:11 AM
buckmc's Avatar
buckmc
Try the Dunlop elite3 and keep thepsi in the rear at 35 solo,and 40 if riding 2.the Elite 3 is what Harley is starting to use on the newer model.Have it on my Electra glide terrific tire
www.tiresunlimited.com
Old Feb 24, 2008 | 09:30 AM
wtkpga's Avatar
wtkpga
My last stock Dunlop got 7k. Your wear is all in the throttle andIloved every min. of it.
