Solo Tour Pack?
Old Jan 26, 2006 | 02:01 AM
Inforit's Avatar
Inforit
Default Solo Tour Pack?
Has any body run the solo tour pack set up? How did it work out? thanks
Old Jan 26, 2006 | 02:10 AM
Terry TK's Avatar
Terry TK
Big Kahuna HDF Member
Default RE: Solo Tour Pack?
My dealer has a 103 ci standard with the solo tourpak. He likes it but I just can't get use to the look. It's very funtional. He uses it as a backrest and runs a solo seat.
Terry
Old Jan 26, 2006 | 09:42 AM
jeepster09's Avatar
jeepster09
I have the detachable setup for both seats, for the dual setup and for the solo. I thought I would only use it once in a while with the solo, but have found I like it alot and leave it on for the most part with my solo seat. Real simple to pop on and off.
Old Jan 26, 2006 | 12:06 PM
Inforit's Avatar
Inforit
Do you have a picture on how it looks like on your bike?
Old Jan 26, 2006 | 02:35 PM
Wolfx's Avatar
Wolfx
Id like to see a photo as well.
Does the detatchable solo tourpac require a seperate mounting hardwear, cause I dont think my dual setup will fit into the backrest mounts if that made any sense??
Old Jan 26, 2006 | 07:12 PM
Inforit's Avatar
Inforit
Solo tourpak is the same tourpak that you have or you can buy, all you need is different brackets for it so it sits right behind the rider and you can use the pak for the backrest.
Old Jan 26, 2006 | 09:48 PM
jeepster09's Avatar
jeepster09
ORIGINAL: Inforit
Sorry don't have very good picture...just snapped this one.
[IMG]local://upfiles/1346/8624BED3A01A40798EE92F288F0ED48D.jpg[/IMG]
Old Jan 26, 2006 | 09:55 PM
jeepster09's Avatar
jeepster09
ORIGINAL: Wolfx
If you have detachable hardware on your bike, you would need seperate mounting brackets/rack to attach tour pack. I have 2 setups, one for when solo seat is on and one for when dual seat is on. They both use same docking hardware attached to bike. I also have seperate passenger backrest if I don't want trunk on bike which again mounts to docking hardware on bike. I really like the ability to switch bike around depending on need.
useR 564357348
May 15, 2010 11:25 AM
dansflhti
Feb 25, 2010 07:06 PM
cannedham1
Jul 21, 2009 09:51 PM
gabulldog
Jul 1, 2008 01:10 PM
tunaman
Apr 28, 2008 02:35 PM
