cam choice for 07' bagger
Old Feb 25, 2008 | 06:03 PM
e666h's Avatar
e666h
Default cam choice for 07' bagger
Anyone do a cam change in their 96in.? Any reccomendations? 07' SG, SE stage1,Rush muffs,Cobra FI2000R.
Anyone with this combo? Dyno results?
Old Feb 25, 2008 | 06:31 PM
Dalton's Avatar
Dalton
Default RE: cam choice for 07' bagger
First off, welcome to the forum. You should go to the new members area and introduce yourself. Your question, has anyone done a cam in a 96" 07 bike, well, look at my signature information
Before anyone can answer what cam is good for your application, you have to ask yourself, what is it you are looking for? More low end power, quicker accelration, more top end speed? Do you ride mostly alone or two up? You mostly ride on the flat or in the mountains. Cams alone or do you want to do other mods, or maybe build in steps. A cam you put in today will not necessarily work with future modifications, although there are those that will.
Lots of questions, but answer those and ask again and I will bet you will get a lot of answers!
Old Feb 25, 2008 | 07:12 PM
e666h's Avatar
e666h
Looking for low -mid range torque. Accelaration. Not concerned about top end power too much.Ride alone mostly.
Old Feb 25, 2008 | 07:18 PM
tom73's Avatar
tom73
HQ 500C cams. Take a look at their website for a dyno-chart. Also go to Latus HD for me information on other cam choices and dyno sheets.
Old Feb 25, 2008 | 07:29 PM
rahall's Avatar
rahall
I was looking for the same improvements as you.
I got them with the Head Quarters cams.
I have a thread with some pictures at https://www.hdforums.com/m_2825599/tm.htm
Old Feb 25, 2008 | 07:30 PM
rick180's Avatar
rick180
https://www.hdforums.com/m_2933412/tm.htm I have these for sale that will fit right in your bike.
Old Feb 25, 2008 | 07:37 PM
Dalton's Avatar
Dalton
Depending what you want to do in the future, a couple of good all around choices would be the HQ 500 or the Woods TW6 or 6H. They will work well with stock compression, and will also handle future modificationsincluding bigger bores and higher compression ratios. I have run Woods cams in the past and they really build torque, as does the HQ. I am now a HQ fan and am running the 575 and so far, it is great!
Old Feb 25, 2008 | 07:56 PM
onefargorider's Avatar
onefargorider
I just finished my cam install. 07 Roadglide. SE 255 cams and the Cobra module. Pulls solid thru the gears and is a nice combo for the stock 96.
Old Feb 25, 2008 | 08:39 PM
UltraKla$$ic's Avatar
UltraKla$$ic
If I do cams only then the Andrews 54H cams(Doughnut Cams)would be the ones I do. Very good results reported at HTT forum.
Old Feb 25, 2008 | 09:00 PM
cardboard's Avatar
cardboard
ORIGINAL: Dalton
2nd the TW6-6 Woods cams, See you have the DTT unit.
If I didn't have it I would go with the TM with auto tune.
Put a Arlen Ness Big sucker II on the bike too.
