Fat Cat falling off?
Old Feb 26, 2008 | 07:04 PM
harleykris's Avatar
harleykris
Default Fat Cat falling off?
I got home after a long ride today(and a deep mud puddle), and as I was wiping her hieness down I noticed that my new Fat Cat had slipped off about 1/2". I know I tightened it down to 150 ft pds, but it still came loose. Any one else have this happen and is there an easy fix. Maybe a hacksaw to open it up a bit? Thanks
Old Feb 26, 2008 | 07:08 PM
CREEPSHOW's Avatar
CREEPSHOW
Default RE: Fat Cat falling off?
Did it come with new clamps?
Old Feb 26, 2008 | 07:09 PM
harleykris's Avatar
harleykris
Yes, the whole thing is new.
Old Feb 26, 2008 | 07:10 PM
rpt63's Avatar
rpt63
Mine did the same thing,I just pushed it back up and then I put a small screw in the rubber pad where the rear of the exhaust bolts up, can't see it and it has not slipped in 1000s of miles
modes's Avatar
modes
I have a rivot in mine for safe measure, but need to tighten the clamp again before riding season.
Adam
Old Feb 26, 2008 | 07:12 PM
harleykris's Avatar
harleykris
Thanks for the tips, just don't want it fall off, that thing is a little pricey!
Old Feb 26, 2008 | 07:13 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
same here with a set of wild pigs i thing its from overtight put a taper on the head pipe . i too finally wedged it at the rubber
Old Feb 26, 2008 | 07:18 PM
maineultraclassic's Avatar
maineultraclassic
Take the muffler off, and use some sandpaper or emery cloth to roughen up the surfaces where the muffler and header meet........that will give it a better surface to grab. Tighten that clamp as much as you can.........just to the point before it's going to snap.
If that doesn't work...........get a "t-bolt" clamp and put that on there in place of the stock one.
Also, make sure the slots in the muffler are large enough and not hitting when you clamp it down. If needed, use a whiz wheel to open them up a bit.
The new Fatcats are coming with a narrower clamp.........supposed to compress better.
Steve
Old Feb 26, 2008 | 07:24 PM
CigarCritic's Avatar
CigarCritic
Did you use high temp gasket sealant? That will do the trick.
Old Feb 26, 2008 | 11:48 PM
atexn4christ's Avatar
atexn4christ
Mine did the same I loosened it pushed it back then cranked on it with out a torque wrench.
doitinthewoods
Touring Parts
Nov 2, 2015 04:58 PM
Groundhog143
Vendor For Sale Classifieds
Oct 19, 2015 06:40 PM
cmoreno42
Touring Parts
Sep 26, 2014 10:41 AM
Hondo11
Jun 7, 2011 02:36 PM
Juno
Nov 25, 2008 06:38 PM
