08 EGC AAT
Old Feb 27, 2008 | 01:31 AM
choochoo's Avatar
choochoo
Default 08 EGC AAT
ok some one on forum said HD moved the temp sensor for the
Ambient Air Temperature Gauge to the frame for the 08 models.
One where exactly did they move it too (picture would be nice)
And is it now accurate? If not how far off would you say it is?
Old Feb 27, 2008 | 05:36 AM
Duracell's Avatar
Duracell
Default RE: 08 EGC AAT
It's up high on the left side of the steering neck. Sorry don't have a pick right now.
And no it still isn't overly accurate. But that's not really an issue.It simply shouldn't be there, accurate or not. I can decide for my self if I need a jacket or not, I don't need any help from HD on that one. It should have been anOIL TEMPERATURE gauge.
Old Feb 27, 2008 | 07:25 AM
Windup08's Avatar
Windup08
I have an 08 UC, air temp guage seems reasonably accurate.....rather useless, but reasonably accurate.
Old Feb 27, 2008 | 09:25 AM
choochoo's Avatar
choochoo
Yeah, but if HD can't produce and install an ACCURATE simple outdoor thermometer,
Then you need to ask yourself, how accurate is their OIL TEMP gauge.
I wouldn't buy it from HD!
I would go aftermarket!!
ORIGINAL: Duracell
Old Feb 27, 2008 | 09:28 AM
choochoo's Avatar
choochoo
What is reasonably accurate?
2 degrees off, 5, 15 ???
I agree it is basically useless.
Except for those of us that ride in cold weather. It could help determine if air temp is actually
cold enough for moisture to freeze on road surface.
well, it could it if the damn thing was accurate!
ORIGINAL: Windup08
Old Feb 27, 2008 | 09:35 AM
hogdoc's Avatar
hogdoc
ORIGINAL: choochoo
ORIGINAL: Windup08
msn.com home page, set it up for your city, weather is on main, page tells you what the outside temp is within an hour and forcast for the whole week!
I usually just go outside to see if its to cold to ride. Look at the street in front of my house to see if there is ice on the road.
Ive riden when it was 3* out so I c geuss I havent found it to be to cold yet!
BTW did you give up on the 5th gear Iam a whiner thread?
Duke of HD's Avatar
Duke of HD
ORIGINAL: choochoo
I plan at some point on getting the HD oil temp gauge I dont feel that there will be an issue with accuracy. I believe the reason that the ambient air temp gauge is "inaccurate" is simply because it is picking up heat from the bike skewing the actual outdoor air temp. I do however feel that it is reading the air temp correctly for its location. Does that make things all better NO, but it does make me believe that when I get an HD oil temp gauge that it will be just fine.
Old Feb 27, 2008 | 09:38 AM
gunrunner's Avatar
gunrunner
why does anyone need a outdoor temp gauge on a open air motorcycle? If its hot its hot, if its cold its cold
davidwruth
Mar 15, 2012 01:23 PM
icnm8uc
Screamin Eagle CVO Models
Nov 20, 2011 04:24 PM
Galdog
Oct 2, 2011 10:39 AM
piasspj
Oct 11, 2007 09:00 PM
a21m
May 8, 2006 01:12 AM
