97 UltraClassic Charging System
Old Mar 1, 2008 | 11:18 AM
network's Avatar
network
Stage I
Default 97 UltraClassic Charging System
The last bike I worked on was my old Panhead and that was almost 30 years ago. I could take it apart and put it back together in my sleep.I bought this 97 UltraGlide about 2 years ago and love it!! But it ain't near as easy to work on as my old "Pan". It's been problem free up til now but the battery has stopped charging. OK, I know it doesn't have a generator, and I know where the Voltage Regulator is but where the hell is the alternator or whatever it is that makes the battery charge?? Can anybody help me please?
Old Mar 1, 2008 | 02:05 PM
White Knight 04's Avatar
White Knight 04
Default RE: 97 UltraClassic Charging System
If you look on the left side of your scoot the primary side ,you will see the wires going to the stator/alt. it is inside of the primary case you will have to remove it...Also the clutch basket and the compositor and the primary chain...then you can see the stator I would advise you to buy yourself a service manual..... I would check the plug at the voltage reg. first and make sure it isn't coroded...Then go from there .... yours should have a 38 amp alt. Hope this helps...Jer
talloldman
Jun 18, 2018 01:48 AM
1999evo
EVO
11
Apr 7, 2015 04:33 PM
CGLTD
May 17, 2013 08:34 AM
bikerlaw
EVO
39
Apr 15, 2012 07:50 PM
GA1dad
Apr 15, 2009 07:53 PM
