evo not charging battery
Old Dec 10, 2014 | 03:56 PM
1999evo's Avatar
1999evo
Default evo not charging battery
I am pretty sure my stator failed, but i wanted to run it by you guys and see if you agree.
My battery is not charging when the bike runs.
Using multimeter on the battery posts I get 12.75 volts when the engine is not running. I start the engine and rev it up, no change, stays steady at 12.75.
With the engine running, I pull the regulate plug off the primary chain case cover. I put multimeter probes (set to ac volts) in the sockets located on the outside of the primary chain case and get no reading. I rev up the engine, still nothing coming from those sockets.
My service manual seems to indicate i should get some type of volts, but i get absolutely nothing. That is why i am unsure.
By the procedures in the service manual, the regulator seems to check out fine. The stator is not grounded and there is no continuity between the sockets on the primary chain case cover.
Any thoughts?
Old Dec 10, 2014 | 04:16 PM
SeaZund's Avatar
SeaZund
make sure you change your meter to AC volts when looking at the stator signal. Your regulator takes AC volts in and converts that to DC volts out
Old Dec 10, 2014 | 05:32 PM
1/2crazedbikr's Avatar
1/2crazedbikr
Boy, all that sounds like deja vu to me. Went through that twice on mine in that last few years.
Sure sounds like the stator to me. But to be sure see Dr. Hess's sticky on "How to diagnose your charging system". All the info you need is right there.
Old Dec 10, 2014 | 05:38 PM
machinehed's Avatar
machinehed
Default no charge.
Any thoughts?
If you have done the tests as per. your service manual then you probably have a fried stator . There is a slim chance that you might simply have a lost connection from the stator to the output cable but thats reaching for sure.
An intermittant short to ground caused by a worn grommet on the primary case is usually the culprit. Remove the primary cover and inspect the stator for obvious heat damage to the coils , inspect the output cable for grounding to the case at the grommet.
Old Dec 10, 2014 | 05:40 PM
Rhino-1's Avatar
Rhino-1
Sounds like you've got a handle on it. After those tests, I too would presume it was the stator and proceed accordingly.
Old Dec 11, 2014 | 06:34 AM
grbrown's Avatar
grbrown
Read Dr Hess's Sticky at the top of this Evo section, to see if there is anything in that which helps. It is designed to assist diagnosing charging problems, after all!
Old Dec 11, 2014 | 01:59 PM
DeputyLoud's Avatar
DeputyLoud
I had a similar issue a while back and thought my stator had failed. Turns out that when I was changing out my levers and adjusting the clutch cable, I had knocked the plug connector loose from the stator on the front of the primary. Mine does not have a very tight connection after all these years and comes off rather easily. That was a huge sigh of relief when finding that saved me $400.
Old Dec 15, 2014 | 12:29 PM
rchop's Avatar
rchop
May I suggest that you replace the stator and the stator rotor. Easy job can be done within one afternoon.
Old Dec 15, 2014 | 04:11 PM
98hotrodfatboy's Avatar
98hotrodfatboy
Default Stator
If you have infinite ohms across the stator definitely has an open. replace it...
Old Apr 7, 2015 | 02:51 PM
1999evo's Avatar
1999evo
Default fixed
it was the stator. the insulation had degraded and the wires shorted out. new stator and i am on the road again
thanks for everyone's input on this, i appreciate it
