sirius radio problem
Old Mar 2, 2008 | 08:19 PM
goutieboy's Avatar
goutieboy
Default sirius radio problem
got the mount for the bike and reception sucks....it is a dock and play radio and in my truck works great, take it off and put on bike awful.in drive waycant get a signal but signal in truck fine,,,any ideas???i know itsinstalled right, no over hangs etc. at wits end.took antenna off truck works fine what is the diff??
Old Mar 2, 2008 | 08:21 PM
UltraDave's Avatar
UltraDave
Default RE: sirius radio problem
Where do you have the antenna on the bike?
Old Mar 2, 2008 | 08:23 PM
adlerx's Avatar
adlerx
My sirius is kinda touchy around buildings, where's your antenna?
Old Mar 2, 2008 | 08:28 PM
goutieboy's Avatar
goutieboy
antenna is mounted by left switch housing on handlebars.the mount is really cool and it is correct.playin around with it earlier i could put my hand around receiver and i would get 2 bars of signal and it would work fine,move hand no signal.went to a local grocery parking lot faced south nothing around at all no signal....on way home it started working fine,went back to the lot wouldnt work!!!no loss of power anything like that just"aquiring signal"
Old Mar 2, 2008 | 08:34 PM
UltraDave's Avatar
UltraDave
I use sirius on my Ultra.
When I had the antenna mounted on the handle bar the reception was poor. I moved it and put it on top of the radio under the bat wing. Bam! 3 bars most of the time. The antenna wants to have a few inches of metal around it to actas part of the antenna which helpsincrease the reception.
Old Mar 2, 2008 | 08:35 PM
1potter1's Avatar
1potter1
Yea I know what you mean,
I haveXMwith a plug and play Roady that works great in my car with no drops. Iwent ona two day850 mile ride and to me it seemed that I haddropped reception alotmore than I had in the past. My antenna on top of my radio inside the fairing
ORIGINAL: goutieboy
Old Mar 2, 2008 | 08:39 PM
jimhr0's Avatar
jimhr0
Try hooking it directly to your radio via an aux. cable from your sirius radio to you HK radio's aux outlet. You will get alot better reception that way. Using the frequency finder does not work very well on the motorcycle. I use an aux. cable in my car and motorcycle and it works great.
Old Mar 2, 2008 | 08:40 PM
goutieboy's Avatar
goutieboy
antenna only has a 3 inch wire, i think that is the problem and have contacted sirius(waiting to hear back) that was my next move, buy another antenna and put it on top of radio(inside fairing) just want to make certain it works that way no problem.dont wana have to pay for another one if ti doesnt work
Old Mar 2, 2008 | 08:44 PM
UltraDave's Avatar
UltraDave
Good luck. Let us know how it turns out.
jimhr0's Avatar
jimhr0
I have my antenna mounted inside my fairing directly on top of my radio. I get great reception and sound even when the radio shows only one bar.
