BACK-OFF Module
Old Jan 29, 2006 | 10:55 AM
gunfighter's Avatar
gunfighter
Default BACK-OFF Module
After almost getting rear ended by an inattentive cager I went out and bught the BACK-OFF module to install on the rear brake light system to automatically flash the brake lights 5 times before they stay on steady. Anyone ever use this module and if so how do you like it and how hard was the installation??
Old Jan 29, 2006 | 11:00 AM
William's Avatar
William
Default RE: BACK-OFF Module
I have one on my sportster and love it.....
took about 5-10 minutes to install ...........
Old Jan 29, 2006 | 11:13 AM
blueknight's Avatar
blueknight
Have installed several on own as well as others rides. Great product and it does help with cellphone mindless individuals.
Old Jan 29, 2006 | 12:28 PM
dchoran's Avatar
dchoran
Could you guys give us the details on this BACK OFF unit???
Who makes them - part number - etc.............
THANKS
sounds like a great safety feature.
Old Jan 29, 2006 | 12:38 PM
rvisdew's Avatar
rvisdew
I use a like product by Kuryakyn (Panacea LED lights) in which the brake light flashes 3 times and then holds steady. Also the turn signals act as running lights ... there are some more specific post on this product ... I like them (sorry, don't have part numbers). Bought from M&M cycles at 20% off ....
Old Jan 29, 2006 | 12:53 PM
Qball's Avatar
Qball
Biketronics makes a couple of nice units, TailStopper and TailRunner.
www.biketronics.com
Old Jan 29, 2006 | 02:30 PM
Ram's Avatar
Ram
http://www.signaldynamics.com/produc...les/wigwag.asp
I used this one on my Travel trunk rear brake lamps. Works great, took about 2 hrs, since I have had to take the travel trunk all off the tour pack (rack) and un-bolt the steel plate in the bottom of the trunk to get to the wiring. Then it was only 4 wires to splice into the factory harness.
Works great I think its the best lighting treatment to the rear that I have done thus far!
Good luck with it.
Gary
Old Jan 29, 2006 | 02:45 PM
springer_'s Avatar
springer_
Something to consider .....
The "back-off" type flasher modules are illegal in some/most/all (?) states.
I LOVE Mine !
Old Jan 29, 2006 | 02:48 PM
Bushy's Avatar
Bushy
I thought the lights in the tour pack were bright enough but I am again wrong. I know back off works and I like the concept . I wonder does any one know how to install signals on tour pack in addition to brake lights??? That would be heaven if any one knew how.. The Back off system worked great on my standard and I went to the HD part that makes your signals running lights, seem to work well. On the open road the more lights the better. If I could put a Christmas tree on my reaR I'd be a happy camper
Old Jan 29, 2006 | 02:49 PM
vegashd's Avatar
vegashd
ORIGINAL: springer_
I LOVE Mine !
really? I did not know that
