Tour pak wiring grommet
Old Mar 3, 2008 | 08:22 PM
twilliams's Avatar
twilliams
Default Tour pak wiring grommet
I just added a detachable king tour pak to my street glide, I also added the spoiler with the LED brake light. I need to fond a grommet for the hole that was already in the tour pak and just assumed that the dealer would have this. I have been to the dealer twice and was given the same answer.....no part number for this grommet. I went to the hardware store and found one that fits the hole but the inner diameter is too big for the wire. Anybody know where to get a grommet? I figure the one intended for the cd ant would be about the right size.
Old Mar 3, 2008 | 08:27 PM
HarleyArcher's Avatar
HarleyArcher
Default RE: Tour pak wiring grommet
Find a new dealer! I went to mine and they had 3 different gromets for me to choose from. My TP didn't have a hole yet so I went with the smallest gromet. If they would just pull the book out and look at the parts list it will give them the number. Atleast this is what my dealer did when I want to get one. Can you find a solid gromet that will fit your hole and then just put a slit the size you need in it for the wire? Hope that helps some. Bryan
Old Mar 3, 2008 | 08:29 PM
Fletch's Avatar
Fletch
We keep a variety of different sizes at the aircraft shop where I work. You might try that if you have any connections, or maybe an electrical supply store. If I knew the right size, I'd send you one.
Old Mar 3, 2008 | 09:13 PM
TexasRedneck's Avatar
TexasRedneck
Try the auto parts store - they've usually got 'em! But you can also go to the parts counter an' have 'em pull the exploded view down of the TP - it'll be there.
twilliams's Avatar
twilliams
ORIGINAL: HarleyArcher
Thanks, the dealership that is only a few minutes from my house has a bunch of idiots working there. The guy even looked at the book (or pretended to) then said nope don't show any gromets..... I don't know why I keeping jacking with those fools.
Anybody with the parts book show a part #?
Old Mar 3, 2008 | 09:39 PM
dawg's Avatar
dawg
57978-00 (2)
11486
11507 (split)
These are the grommets I show on a tourpak, not sure which one you need.
Old Mar 3, 2008 | 09:42 PM
twilliams's Avatar
twilliams
Thanks everybody and once again DAWG......you are the man!
Old Mar 3, 2008 | 09:48 PM
twilliams's Avatar
twilliams
Dawg, just curious were those from the touring parts book? I want to bust these jacka$$e$ tomorrow when I go in with part #'s.
Old Mar 3, 2008 | 09:56 PM
Lu's Avatar
Lu
Dawg is right, the part # for 3/4 inch grommet to cover the hole for the antenna cable is is 11486.
Bought the FLHX King TP and got the part number from the instruction sheet.
Hope this helps.
[align=left] [/align]
Old Mar 4, 2008 | 06:33 AM
dawg's Avatar
dawg
ORIGINAL: twilliams
Sure were, located on the tourpak bottom section
