Why is my brake light on?
Old Mar 9, 2008 | 09:44 AM
TexasBowhunter's Avatar
TexasBowhunter
Default RE: Why is my brake light on?
These guys have got you covered...
I've done the same thing...
The front brake switch was the culprit...
Learned a $75 leason that day...
Old Mar 9, 2008 | 10:14 AM
6speed's Avatar
6speed
Does replacement of the front brake switch require cutting and splicing of wires or just a replacement procedure? Thanks
Old Mar 9, 2008 | 10:41 AM
6speed's Avatar
6speed
Also,does anyone have a part number?
Old Mar 9, 2008 | 10:56 AM
captsam54's Avatar
captsam54
Happened to me too.. Warranty work after I bitched at them. 2 little pieces of electrical tape before that..!
Happened to my Buddie the other day on a ride.. I knew exactly what it was..!
Old Mar 9, 2008 | 12:51 PM
6speed's Avatar
6speed
I opened the switch assembly and I see the brake switch,I can operate it manually and it doesn't look like anything is wrong with it.It's enclosed in a rubber case with a little round hole on the end,I think I will glue a spacer on it and later have it fixed under warranty.Will spraying some WD-40 into it help or will that create more of a problem? Thanks
Old Mar 9, 2008 | 01:01 PM
dougbk's Avatar
dougbk
Yes it does.
Joshus41
Sep 27, 2016 02:41 AM
Briguy1
Electrical/Lighting/Alarm
Feb 9, 2015 06:10 PM
Skeezmachine
Oct 2, 2010 11:49 PM
swilsondds
Apr 28, 2008 07:54 PM
AZCHOKESTER
Jan 10, 2008 10:34 PM
