Engine crash bar as oil cooler?
Old Mar 9, 2008 | 01:51 PM
Mississippi Bagger's Avatar
Mississippi Bagger
Default RE: Engine crash bar as oil cooler?
ORIGINAL: Vegas FLTRI
I did that mod to my roadglide and it makes a great difference here in the desert. Oil only passes through the bar when the thermostat opens at 185 and let me tell you if you grab mine in the spring/summer when the oil temp is up at 200-220 you won't hold on for long,
Hi Vegas,
Where did you run your lines from the crash bar? To an oil filter adapter, or to the low pressure return lines on the side of the engine?
Thanks.
budwfo's Avatar
budwfo
add states 1.5 extra in oil
Old Mar 9, 2008 | 02:33 PM
Bill03E's Avatar
Bill03E
If you have an old electric fuel pump laying around you could make it flush it out , I would use K1 or somthing like that, because if you use gas or laquer thinner it would rust as fast as you could remove it.
You can buy a hand crank pump for RC planes to fill them up, for about $20.00 at a hobbie store.
Old Mar 9, 2008 | 02:36 PM
smitty901's Avatar
smitty901
thing about oil cooler is they really on work when moving unless you add a fan.
they only reduce temp a small amount.
Take a look at HD or the Lenale cooling fans they will drop temp a lot compared to oil cooler.
Old Mar 9, 2008 | 02:52 PM
Vegas FLTRI's Avatar
Vegas FLTRI
from an oil filter adaptor. i flushed it out with kerosene and then compressed air
ORIGINAL: Mississippi Bagger
Hi Vegas,
Thanks.
Old Mar 9, 2008 | 02:54 PM
Vegas FLTRI
it works better when air is moving over it but it still works even when sitting still, it is called convection, same as the old steam heaters used to work
ORIGINAL: smitty901
Old Mar 9, 2008 | 05:08 PM
DADAWG's Avatar
DADAWG
ORIGINAL: smitty901
just the added oil volume should help some
Old Mar 9, 2008 | 08:40 PM
Motown_HOG's Avatar
Motown_HOG
I had a buddy that did that mod. He had no problems, but those bars got damn hot!
Old Mar 9, 2008 | 09:10 PM
1Harleyrdr's Avatar
1Harleyrdr
Seems like a good idea
Old Mar 9, 2008 | 10:01 PM
skltr's Avatar
skltr
Innovative!! [sm=goodidea.gif]
