Engine crash bar as oil cooler?
Old Nov 23, 2010 | 07:10 AM
  #31
Ultra Street Jewell's Avatar
Ultra Street Jewell
With all the different brands and styles of oil coolers out there, why would you monkey around with your highway bars?
Old Nov 23, 2010 | 06:45 PM
  #32
heavyhitter01's Avatar
heavyhitter01
Thanks for the advice, but I just need the oil filter adapter part number or a working link to get the parts list.
Old Nov 23, 2010 | 07:03 PM
  #33
bigdumbnoitall00's Avatar
bigdumbnoitall00
the crashbar is a whole lot thiker than the stuff they make coolers out of, ive seen more than one cooler with leeks from stones hittin it never seen a hole in a crashbar from a stone.
Old Nov 23, 2010 | 07:10 PM
  #34
heavyhitter01
I think this is what I am looking for http://www.jpcycles.com/product/740-909
Old Nov 23, 2010 | 07:26 PM
  #35
bigdumbnoitall00
ive seen this done, drilled and tapped the flats on the bottm on each side of crashbar and used threaded barbed fittings.
Old Nov 23, 2010 | 07:38 PM
  #36
fritz982's Avatar
fritz982
Default crash bars as oil coolers.
I tried that idea just once a long time ago, and to be up front it's not very effective at all. The idea for the most part is completely inefficient, all it winds up being is a large straight pipe run your oil through. This whole idea has been really around for quite some time! I too can remember, when I first had the idea I saw it on a pan had. In those days some people learn the hard way through oil starvation that this was not a very bright idea. In those days Harley oil pumps were not as efficient as they are today. To make a long story short a specifically designed oil cooler is just plain, way more efficient at cooling oil! Take a look at Jagg's web page and they will give you a complete rundown along with diagrams, that will help you understand why their product is so efficiently designed. Save your money, buy the product that's designed specifically for the job.
Old Nov 23, 2010 | 08:54 PM
  #37
bmcgc's Avatar
bmcgc
The crash bar is just a big heat sink and the added volume of oil will reduce operating tempature. Thats just science, cant dispute that.
My concern would be that after shutdown gravity will allow the oil in the crashbar to drain back into the lowest point. The oil pan. If the level of the oil is high enough to come in contact with the crankshaft, on startup the crank will whip the oil into foam. Aerated oil will not be picked up by the oil pump in sufficent amounts to properly lube the engine.
Im curious what the oil level is before startup when 1.5 qts are added for the crashbar.
Old Nov 23, 2010 | 09:16 PM
  #38
Sharknose's Avatar
Sharknose
Originally Posted by Maclugie
That will void the warranty. LOL
I don't think that anybody who would tackle a project like this is worried about getting work done at the dealership. And as to why would you do this? Why the hell NOT? That's part of the fun.
Old Nov 23, 2010 | 09:20 PM
  #39
Sharknose's Avatar
Sharknose
Do you really ride an "Electric Glide"?
Old Nov 23, 2010 | 09:23 PM
  #40
pococj's Avatar
pococj
LOL, if'n it don't come from a stealer and bolt on with two Chinese Grade 2 bolts, it ain't no good! I hate cookie-cutters.
