why do i pop?
Old Mar 13, 2008 | 04:01 PM
2008FLHP's Avatar
2008FLHP
Default why do i pop?
'03 RK, KN filter, VH propipe, PC3 w/correct canned map (though it says for 2002) and it still pops on decel AND pops right when i squeeze in the clutch when upshifting too...exhaust is tight and the plugs look fine
yeah i know i should get it dynoed...confused...any ideas why?
Old Mar 13, 2008 | 04:59 PM
Xtreme Hawg's Avatar
Xtreme Hawg
Default RE: why do i pop?
If I had to guess, I'd say it was your map... It's possible the map you've programmed is not right for your bike and setup. Had the same problem with my old bike and after changing my map it ran great... "D"
Old Mar 13, 2008 | 05:51 PM
Lincoln33's Avatar
Lincoln33
I bought my 01 RK used and the previous owner had put aftermarket exhaust on without remapping. I had the same problems your having now. I went to the local dealer and had a "Stage 1 Reflash" and the hot and cold idle reset ($216). No problems since. Iknow you did the PC3 remapping but I didnt know if that was a similar fix. FYI Good luck on the fix.
Old Mar 13, 2008 | 08:21 PM
notlost_nc's Avatar
notlost_nc
see if the first column of your map has zeros in it, you may need to change them to fives. Lots of info on the "decel popping" here.
Old Mar 13, 2008 | 08:35 PM
davewear's Avatar
davewear
canned map, popping could mean rich or lean. get it dyno tuned....
Old Mar 13, 2008 | 08:45 PM
EdwardK's Avatar
EdwardK
Is a little decel popping a bad thing?
Every standard transmission vehicle I have ever driven had some decel pop if you ran up the rpm in a gear and just let off the gas. Especially if it had any kind of exhaust on it.
Old Mar 13, 2008 | 09:08 PM
FLHT's Avatar
FLHT
Mark my word, just like notlost said. You put some fuel in that 0% column, 5 to 7 and it will go away. Been there done that.
Old Mar 14, 2008 | 06:59 AM
2008FLHP's Avatar
2008FLHP
here's the maps...top one is STOCK ECM...that's the one I'm using...so you think my problem is above 2500rpm?...any help in adjusting?
[IMG]local://upfiles/42378/6F9D1275406A40B99C1B39C1B63520FB.jpg[/IMG]
[IMG]local://upfiles/42378/551592813CB34956A471A9D3B8977030.jpg[/IMG]
HyperM3
Jun 10, 2019 03:57 PM
JZFloatingkent
The Dyno Room
May 16, 2017 12:50 AM
G9803
Engine Mechanical Topics
Aug 1, 2014 11:47 AM
stagolee
Apr 18, 2008 07:46 PM
JWilson
Exhaust System Topics
Feb 21, 2008 07:05 PM
