PCIII Issues
Old Mar 13, 2008 | 09:16 PM
randlock's Avatar
randlock
Default PCIII Issues
[:@]Put a PCII USB on my bike. Rinehart t/s and S/E Air Filter. Got to cruising speed and she died. Missing, popping, b/f u name it. Did I get a lemon PC. btw this was w/o and w/map.......input???
Old Mar 13, 2008 | 09:29 PM
FLHT's Avatar
FLHT
Default RE: PCIII Issues
First off I dont get it, with and without map. You have to have something there. Did you set 0 and 100% throttle. When you pluged in your PC to your computer pig tail did you wire tie that connection together, did you use dilethium grease on the connections, are you getting any engine light or setting any codes? Who did you buy your PC from, If it was from Fuel Motto, the map he would have loaded is damn near spot on.
I suppose you could have gotten a bad one, But there are a lot of other un-answered questions.
Old Mar 13, 2008 | 09:35 PM
randlock's Avatar
randlock
There are no pig tails. The 08' plugs direct between the ecm and harness. Set buttons at zero and richer. Same difference. Downloaded the map right from the PC website w/disc. It just flat out didn't perform. Removed PC roadside and everything was fine.
Green Machine 04
Exhaust System Topics
Oct 2, 2010 07:43 AM
eglinski
Mar 21, 2009 09:24 PM
phatbobby
Jan 5, 2009 07:51 PM
timberland
Mar 10, 2008 10:48 PM
street glider ac
Aug 20, 2007 03:53 PM
