fog light acc wiring
Old Mar 17, 2008 | 06:54 AM
dunnp650's Avatar
dunnp650
Default fog light acc wiring
what is the part number for the wire adapter to wire fog lights so it will bring relay on with the acc switch it is the one under seat on 07 electra glide
Old Mar 17, 2008 | 06:56 AM
TexasRedneck's Avatar
TexasRedneck
Default RE: fog light acc wiring
huh?!??
Old Mar 17, 2008 | 10:39 AM
dunnp650's Avatar
dunnp650
there is a plug under my seat that is contolled by acc switch I need a pigtail that will plug into that so I can wire my fog light relay into
Old Mar 17, 2008 | 11:11 AM
Harleypingman's Avatar
Harleypingman
It's a four wire Deutsch male connector. You can get the part number from the parts breakdown on the saddlebag mounted spoiler/LED kit HD sells since that is how the kit's instructions call for the LED's to be wired or PM Dawg or TwinCam47.
Old Mar 17, 2008 | 11:25 AM
RonH's Avatar
RonH
to wire my Boogey Lights into the ACC dash switch I used part #70264-94. Tested all 4 pins to determine which wire was the acc switch and which the ground, then cut off one of the two connectors, terminated the other two wires and soldered directly to the wires I needed
[IMG]local://upfiles/9233/E4A2B023AC9C4D0E9719B4C477731FEF.jpg[/IMG]
Old Mar 18, 2008 | 07:58 AM
dunnp650's Avatar
dunnp650
thanks RonH I did that and works great
khurtt
Aug 27, 2015 02:24 PM
mstrobes
2014-2024 Touring Models
Jun 27, 2015 01:09 PM
CroGlideUltra
Jan 5, 2014 07:23 PM
pontiac69
Aug 3, 2012 05:34 PM
Mtnwarrior
Apr 1, 2012 02:28 PM
