Need help wiring
Old Mar 31, 2012 | 12:05 PM
Mtnwarrior's Avatar
Mtnwarrior
Default Need help wiring
Posted this in electrical but got no response. I need help wiring my Custom Dynamics LED lights that I am putting on my engine guard. I have virtually no clue how to wire these and they come with no harness or instructions. I ordered the MOCO harness that leaves them on regardless of high/low beam, but have no clue beyond that. Can I just wire them straight to the ACC switch? Is that hot all the time? I wired a whole house, but bike electronics confuse me. I can afford just sending bringing it to the stealership, but want to learn more about my bike. Can someone help me?
Old Mar 31, 2012 | 12:09 PM
speedwaysteve's Avatar
speedwaysteve
You can use the acc swich its under the seat by the gas tank.i got the harness for the acc plug from harley so i didnt cut the acc plug
Old Mar 31, 2012 | 12:16 PM
mkguitar's Avatar
mkguitar
the acc plug has multiple pins ( depending year /model)
My 09 has pins for:
acc switch controlled 12 VDC +
12 VDC + "on" with ignition/light ( fused with the P&A fuse- this hot then runs to the Acc switch above)
12 VDC + "on" with brake light
use a test light and you'll see which is which
Mike
Old Apr 1, 2012 | 06:38 AM
Mtnwarrior's Avatar
Mtnwarrior
So, Speedwaysteve, you are saying that I can attach wiring, using those little ends that attach to wires and then plug into a harness, into said harness and that harness plugs into a plug under the seat? Is it labeled by any chance? Did you use the harness from MOCO that allows high/low beam constant on?
Sorry, I hate to keep asking questions, but just not familiar with it.
Old Apr 1, 2012 | 02:28 PM
Harleypingman's Avatar
Harleypingman
If you want to use the accessory connector under the seat, the parts you will need are identified in this link:
http://www.harley-davidson.com/en_US...ts/-J01544.pdf
The parts you will want are 1, 4, and 6 in the picture on the first page.
The switched circuit in the ACC connector is chamber 3, and chamber 1 is the ground. The numbers are very small and are embossed at the wire insertion side of the connector.
Suggestion: Buy the HD service manual for your bike--best accessory purchase you will ever make IMO.
Carl
kishstl
Apr 12, 2016 02:46 PM
Pyrotag
Electrical/Lighting/Alarm
Apr 17, 2014 03:55 PM
CroGlideUltra
Jan 5, 2014 07:23 PM
2LOUDCVO
Mar 18, 2012 07:39 PM
dunnp650
Mar 18, 2008 07:58 AM
