power commander help
Old Mar 19, 2008 | 10:00 PM
Born2cure's Avatar
Born2cure
Default power commander help
Just finished putting on the Bub 7 true duels, and stage 1 air cleaner on my 2008 ultra. I have ABS and have no idea how the connection for the pcIII fits in front of the battery as the instruction state. And then mounts under the seat. Any help would be appreciated.
John
Old Mar 19, 2008 | 10:31 PM
dowork08's Avatar
dowork08
Default RE: power commander help
it will work, i had to cut my battery box cover so it would slide over the battery cables that were moved a bit, also i had to take a hair drier to heat up the big wire harness that is in the way, once it is heated it moves a bit and the connector will slide down in there. hope that helps, i was in the same place you are now, going how the hell does this fit
Old Mar 20, 2008 | 12:13 AM
bikerbehaviorist's Avatar
bikerbehaviorist
You also may want to take a look at this. I have not tried it, but book marked for the day when....
https://www.hdforums.com/m_2862082/m...tm.htm#2862082
Old Mar 20, 2008 | 12:36 AM
Bertk's Avatar
Bertk
ORIGINAL: Born2cure
John
The PC3 installs on the right side of the battery box on 2008 touring models, as shown in the following installation instructions. Are you sure you have the correct model PC3, as shown HERE.
Old Mar 20, 2008 | 04:04 AM
bpd138's Avatar
bpd138
It dosen't if you have ABS.
Old Mar 20, 2008 | 10:36 AM
Bertk's Avatar
Bertk
ORIGINAL: bpd138
I didn't read down far enough, thanks for the correction.
I can't say I like the fit of PC3 on ABS bikes. []
fame2
Dec 4, 2014 08:53 AM
LQQK_OUT
Audio Systems
Oct 22, 2013 11:36 PM
see22ds
Sep 17, 2013 06:40 AM
tatertot
Dec 18, 2008 04:18 PM
flharleycop
Nov 5, 2007 04:14 PM
