Popping through exhaust cause found?
Old Mar 25, 2008 | 10:04 PM
DiegoKing's Avatar
DiegoKing
Default Popping through exhaust cause found?
Hey all,
As some of you know I've been experiencing alot of popping through the exhaust on deceleration. Well, I think I found out why. Some of you suggested an air leak so I started the scoot and started spraying carb cleaner around the throttle body and on the front cylinder where it bolts up it damn near stalled when I spryed it there but not at the rear cylinder. So, I am pretty sure I have a leak at the front cylinder/manifold mounting area. So, my next question is how in the hell do I get the throttle body off? It does not look easy, I am not looking forward to this. Any suggestions? Thanks in advance.
Old Mar 26, 2008 | 05:21 AM
Big Peter's Avatar
Big Peter
Default RE: Popping through exhaust cause found?
ORIGINAL: DiegoKing
Hey all,
When you have the manual and some good tools
you can do it in 45 minutes.
Peter
Old Mar 26, 2008 | 06:25 AM
Zimbob's Avatar
Zimbob
Invest in a shop manual, it's worth it's weight in gas, it will walk you through the whole deal.
Old Mar 26, 2008 | 06:56 AM
dog155's Avatar
dog155
Try tightening the manifold first! Just snug them down and see if it makes a difference.
Old Mar 26, 2008 | 08:59 PM
DiegoKing's Avatar
DiegoKing
I've got a manual, do I really have to remove the tank or is there an easlier way?
Old Mar 26, 2008 | 09:36 PM
choochoo's Avatar
choochoo
yep service manual!
Not hard, but beware the mounting flanges only go back one way!
Old Mar 26, 2008 | 10:08 PM
vibr8ir's Avatar
vibr8ir
my bike had the d-cell pop too.. took mufflers off put some copper exhaust
gasket sealer on the joint put all back together no more pop. only need a
little lite film or you'll make a mess.. good luck.. Steve
Old Mar 26, 2008 | 10:31 PM
FLGEEZ's Avatar
FLGEEZ
ORIGINAL: DiegoKing
Muckin around under the tank isn't the easier way. I have tried to tighten the intakes bolts that way and some money and a new temperature sensor and the time it took to replace it later....
That's on an 96 EFI, maybe not same, but it's your bike. Use the manual info or go fish.
Old Mar 26, 2008 | 10:55 PM
Paniolo's Avatar
Paniolo
I see you have a 2001 RK, which means it's a Magetti-Marelli. For that TB you will need a couple of different types of allenhead wrenches. The only way I was able to undo some of them was withball heads with long shafts. Get the ones for 3/8" drive ratchets, not the "T" or "L" handles. It has to be long enoughto go through that little arched passage way that sits in the front of the TB, and reach all the way to the allen headto do it.
Depending on how patient you are, you may be able to to it without removing the tank. Just undo the rear bolt, and the two front bolts, and wedge a small block of wood under the tank to lift it up and give you clearance. Be careful removing the injector wires as they tend to get brittle from heat and can break. Always use new gaskets when reinstalling. I coat the gaskets with warm soapy water. This makes them pliable and easier to shift around and when seating. If it's cold where you are, the gaskets could become harder to work with, and thus not seat properly.
Also look for exhaust leaks too. With the bike running, take your bic clicker fire starter and hold the flame up to the exhaust flanges, and EVERY joint working your way back. If you see the flame flicker and move, you have found leak.
Others may chime in with their tips, but that is what has worked for me.
c-note
Apr 29, 2014 10:12 PM
sj032885
Ironhead
Apr 3, 2014 09:41 AM
PJRED70
Ironhead
11
Feb 26, 2013 08:03 PM
Cygnus x-1
Jun 9, 2011 04:04 PM
sanmanbob
Ironhead
18
Jun 6, 2010 03:11 PM
