grips 07
Old Mar 26, 2008 | 10:27 PM
cirhere2's Avatar
cirhere2
Default grips 07
Changing grips on 07 uc any tips or tricks besides watching for the little ferules
I have the manual but figured you guys had some tricks
Russ
Old Mar 26, 2008 | 10:34 PM
Peatster's Avatar
Peatster
3rd Gear
Default RE: grips 07
Check out the Kuryakyn web site. It has a .pdffile of detailed directions that are easier to follow than the HD Manual.
PN
Old Mar 27, 2008 | 07:07 AM
Peppa1's Avatar
Peppa1
Pretty easy install. Like you siad the little brass gremlins are the hardest part. If I were you I would trade my bike for an 08 and then you want have those little brass things !!! LOL
Old Mar 27, 2008 | 09:13 AM
cirhere2's Avatar
cirhere2
lol now that would be an expensive change just for those $%^^^%$ ferruls
Old Mar 27, 2008 | 09:31 AM
SteveB FLH's Avatar
SteveB FLH
Picks work wonders for handling those ferrules. The grips are a fairly easy install...process took less than an hour. Remember to protect your tank from possible scratches while installing. Also a very good time to lubricate and check clutch and throttle cables......
Old Mar 27, 2008 | 04:56 PM
Rhubarb's Avatar
Rhubarb
Don't forge to shim the brake lever with cardboard. This is the most pain in the *** mistake you can make doing this.
If you break that switch, you will wish you had just lost ferules even if the moco charged $100 for them.
Toss a towel on the ground under the throttle grip to catch em if they drop.
To avoid any hassle of removing the left grip, i gut it lengthwise with a razorblade. Took seconds to remove that way.
DesireBagger
Oct 23, 2018 06:05 PM
Cotton Hill
Mar 24, 2011 08:58 PM
dragonglide
Apr 1, 2009 06:44 PM
harley-jones
Mar 5, 2009 04:04 PM
briggs07
Oct 15, 2008 11:23 AM
