Low Profile Shock Air Pressure ??
Old Mar 28, 2008 | 03:44 PM
SCRider's Avatar
SCRider
Default RE: Low Profile Shock Air Pressure ??
25psi for two up riding seems about right. Try the 15 psi, but it might seem like you are riding up hill with two up. Through experience I have found that less pressure does not translate into more comfort.
Old Mar 28, 2008 | 06:29 PM
TheBlackBastard's Avatar
TheBlackBastard
I have had these shocks for about 3 years. I've consistently run about 16-20 lbs in them no matter what type of riding. I think it boils down to personal preference.
Old Mar 28, 2008 | 06:42 PM
SoCal_Pappy's Avatar
SoCal_Pappy
By changing in to a lowering shock you have reduced the shocks travel which means you should need additional air pressure for proper clearance . By increasing the air pressure will give you a firmer ride... I would recommend starting @ 25 lbs & working up... I have had lowering blocks to lower my rear and needed to run 50+ as to not bottem out 2-up loaded.
Keithhu
Nov 21, 2012 10:47 AM
roadking2014
Oct 15, 2012 07:45 PM
stevieg
Jun 22, 2009 09:16 PM
eztimez2
Apr 13, 2008 09:03 PM
Secretec
Feb 27, 2008 02:07 PM
