Need a new clutch
Old Mar 29, 2008 | 03:39 PM
sewerat's Avatar
sewerat
Default Need a new clutch
OK now that i have the Fat cat and the DTT both working well, the clutch has started to slip again, When I put the big bore in last year it did a bit, so i adjusted it and it was fine for last summer. Got out for a bit of a nice ride today and if I hammer on it the clutch will slip. What I am looking for is a good clutch without breaking the bank and without killing the hand. I have used the SE race clutch before and that is TOO much pull for what I need now. I am unsure if all I need to do is put in some decent plates and change out the stock spring or which direction to go with it? Also does anybody know if the stock spring from a 96" is any stronger than the stock spring from my 88" I know the harley big bore kits came with a stiffer spring for the 95" but i didn't buy that kit therefore never put the spring in? But I do have a stock 96" spring in the tool box.
Old Mar 29, 2008 | 03:42 PM
Forget About It's Avatar
Forget About It
Default RE: Need a new clutch
check the sponsors on the bittom of this page
Old Mar 29, 2008 | 06:02 PM
sewerat's Avatar
sewerat
OK like the saddlebag guys? or the k&n or the J&M, or maybe the shifter linkage, or maybe Fix My Hog...but I already do that??? I hit refresh about 20 times to find a vendor that would have a clutch, the closest i found was eastern performance? and I could not find a clutch on their website.
Old Mar 29, 2008 | 08:35 PM
harleyeglideman's Avatar
harleyeglideman
I use the MĂźller Power Clutch in both of my bikes each of which have substantial performance work done to them. I am very happy with them and have had no issues to date. Good luck.
http://www.partsmag.com/0503/Drag-Muller-Ed-0503/Drag-Muller-0503.html
See prior thread:
https://www.hdforums.com/m_3037917/tm.htm
Ride safe. [sm=signs003.gif]
Old Mar 29, 2008 | 08:37 PM
TXCHOP's Avatar
TXCHOP
A vpc would work great!!!
Also eneryone make replcement plates that are great and will hold for a little over a hundred.
Did you try the S/E spring?
Old Mar 29, 2008 | 08:41 PM
1Harleyrdr's Avatar
1Harleyrdr
I have had good luck with barnett clutches and spring kits
Firemn17
General Topics/Tech Tips
Jul 21, 2016 12:25 PM
jeffbetrollin
Dec 8, 2015 02:15 PM
harley#1
Nov 30, 2014 10:33 AM
D W K
Sep 29, 2014 07:59 AM
Boxer Harley
Feb 13, 2007 12:32 AM
