street glide
Old Mar 30, 2008 | 12:32 PM
rjgraham's Avatar
rjgraham
Default street glide
Any big changes between 2007 and 2008?
Old Mar 30, 2008 | 12:38 PM
drrandall1's Avatar
drrandall1
Default RE: street glide
07 had 5 gallon tank. 08 has 6 gallon tank. The brakes are supposed to be better.
Old Mar 30, 2008 | 12:50 PM
BadX's Avatar
BadX
New for 08 throttle by wire, ABS available, floating disk, 6 gallon tank as mentioned above, new seat mounting system so only 08 seats will work.
Old Mar 30, 2008 | 12:54 PM
drrandall1's Avatar
drrandall1
throttle by wire and floating disk? What does that mean?
Old Mar 30, 2008 | 01:03 PM
electaRICK's Avatar
electaRICK
throttle is electric,, no more push pull cables
floating rotor,, means its not a solid brake disc
Old Mar 30, 2008 | 01:06 PM
drrandall1's Avatar
drrandall1
Gotcha thanks. Sounds like they really did some good improvements this year.
Old Mar 30, 2008 | 04:47 PM
KSGLIDEGUY's Avatar
KSGLIDEGUY
Don't forget IDS. Standard on 08's
Old Mar 30, 2008 | 05:37 PM
izzi's Avatar
izzi
copied f o f>>>>>" ???????????????????????? can anyone clarify?
".Significant changes 07-08 What HD doesn't tell you
Got the 2008 touring model catalog in my hands and quickly went through a comparison of engine/gearbox components with the 2007 touring models. Some of the changes are hidden deep in certain components.
Engine
* front head (new front motor mount)
* crank bearing
* cams
* induction module (new fly by wire system)
* Stator assembly
* new ECM etc (new fly by wire system)
* crank shaft position sensor
* Starter assembly
* starter clutch subassembly
Gearbox
* clutch cable
* transmission assembly
* transmission case subassembly
* lock rings 11081 A
* Inner primary bearing inner race
* Input shaft
It appears to me that the MoFoCo addressed the major issues with the 07 drivetrain in a sneaky way.
Cams to deal with the pinging and likely the overheating, the starter to address premature failures and maybe the noise and my absolute favorite , new transmission assembly with new case, input shaft, bearings and a few other minor things to deal with the non existing 07 transmission problem."
again....can anyone clarify this or are there part# changes involved?
Old Mar 30, 2008 | 06:09 PM
1Harleyrdr's Avatar
1Harleyrdr
somebody sounds a littlte angry
Hafner01
Oct 26, 2018 07:44 AM
TLONG
Mar 16, 2014 09:10 AM
ultralongridesoreass
Sep 13, 2009 11:49 AM
angelo
Oct 24, 2007 08:18 PM
62trvler
Sep 28, 2007 12:16 PM
