Thank You, John TN and HD Forums! Cruise Control Problem
Old Mar 30, 2008 | 05:20 PM
HEMSPLT's Avatar
HEMSPLT
Default Thank You, John TN and HD Forums! Cruise Control Problem
I just wanted to post a thanks to John TN and all of you other experts that help those of us that have the skills but not the knowledge/experience.
Last week my cruise control quit working on my '02 UC. I havethe service and parts manuals but not the electrical manual. I used the schematics in the service manual to check connections and used my volt/ohm meter to check for continuity but I couldn't figure it out. I also retrieved the self-diagnostic codesfrom the system but that didn't help. The problem is the throttle roll-off switch, which I never use. I figured this out by reading and following the instructions John TN posted on 5-20-06. Without his post I probably would've thrown money at a new cruise module I didn't need. In this case I have my cruise control working again and it didn't cost me a dime since I won't replace the switch, at least in the near future. Maybe one day I'll invest in an electrical manual.
I pasted John's info below to try andsomeone else in the future.
Thanks again, John. [sm=deal.gif]
John's 5-20-06 post regarding cruise control:
Same problem with mine, had trouble with it last year, work some then not work, if it's the cable roll off switch easy check. At the neck just in front of the gas tank is where the cable switch is under the rubber boot. Disconnect the two wires from the switch, tape them serparely and see if the cruise works o-k. I'm still not using the roll of switch, they just tear up to damn easy, screw it. If it's not the throttle roll off switch then you will need a service manual to perform the other cruise control system checks.
Also this is good info if you're on a long trip and the TRO switch goes out you can disconnect and still have the cruise if it's a bad switch. Your brakes and clutch lever when pulled will still kick the cruise off just like a car, you just won't have the throttle roll off, which really to me really isn't neccessary IMO, I'd rather see a non engine start switch on the clutch and kickstand instead of the roll off.
Old Jul 7, 2008 | 11:50 AM
John TN's Avatar
John TN
Default RE: Thank You, John TN and HD Forums! Cruise Control Problem
You're welcome,,, just found this thread while doing some research on some other stuff. Always check the throttle roll off switch first if you're having cruise control issues,, my roll off cable switch is still disconnected and my cruise has worked flawless ever since then.
Pothole914
Oct 14, 2015 10:26 PM
rlj50
General Topics/Tech Tips
Jul 12, 2015 06:25 PM
joesquid
Jul 16, 2013 02:10 AM
Guntoter
Aug 21, 2012 11:37 AM
JC650
Jun 23, 2011 06:39 PM
