Changing up heads and cams
Old Apr 3, 2008 | 01:45 AM
olgreydog7's Avatar
olgreydog7
Default RE: Changing up heads and cams
Based on what you just said, do some mild head work and pick one of the cams listed. You can play with the CR using gasket thickness if you need to. These motors are just like that old small block you used to play with. They respond to the same things. Especially if cash is limited. Firgure 250-300 for cams, 300-400 for head work, then all the other misc parts, gaskets, ect. Doing all the work your self will save you ALOT. Then, however much your tuner charges for dyno time and you are set. You basically have the same goals as me and that is what I am doing. Self ported heads, SE-204 or HQ 0034 cams, a PCIII or SERT(depends on who I get to tune ad what they prefer) and call it a day. Good luck
jeffreyjames
Jun 8, 2011 05:25 PM
el chivito76
Exhaust System Topics
May 3, 2011 09:02 PM
FLHXXHLF
Mar 28, 2009 06:34 PM
gsreimers
Apr 19, 2008 06:27 AM
THNDR
Feb 1, 2008 01:13 PM
