fuelmotousa?
Old Feb 9, 2006 | 01:02 PM
shark's Avatar
shark
Default fuelmotousa?
Has anyone purchased a powercommander from these guys? Wondering how well the pre-loaded map has worked for those that have tried.
It has been an unusually mild winter here in the Boston area, so I am getting more anxious to do my mods before the spring.
Ordered the SE air cleaner and SE pro one piece slip ons from Zanotti's - expected to arrive for the weekend work.
The general opionion I have observed from the posters on the forum is that ultimately a dyno - tune is the best way to dial in the bike. Have a good guy close by, J&D Cycles in Hyde Park, an I will likely end up there once the weather is warmer and sand is swept out of the corners.
I assume that the pre-load will be acceptable until I can get to the dyno.
Thoughts?
Thanks,
Mike
Old Feb 9, 2006 | 01:04 PM
Terry TK's Avatar
Terry TK
Big Kahuna HDF Member
Default RE: fuelmotousa?
If you have a preloaded map that matches your upgrades you will be fine. The bike might actually run pretty good but the dyno is a must to dial in your performance without losing fuel economy.
Enjoy!
Old Feb 9, 2006 | 04:00 PM
tcfamy's Avatar
tcfamy
I purchased my PC III from fuel moto last year. it was a very good experience. They preloaded the map I requested after talking with dynajet directly. It worked well but I did tweak the unit manually to correct some over richness. Absolutely have a dyno run planned to optimize the situation. It is a small investment and big improvement. If you are near Fuel Moto they have a brand new Dyno 250 and are certified.
Tom
Old Feb 9, 2006 | 04:04 PM
shark's Avatar
shark
thanks tom and terry. sounds like I'm on the right track.
I will take your advice and get the dyno done. Would like to ride it to WI to haev the dyno done. But I don;t think I can squeeze in the vaca time. Haven't been back to Milwaukee since I graduated from Marquette in '84.
Thanks again.
Old Feb 10, 2006 | 02:52 PM
territory145's Avatar
territory145
Just finished install of pre-programmed PClll from fuelmoto. They did a great job dialing in my K&N stage 1 a/c and V&H oval slipons. The bike has never run this good. IMO you can't go wrong with FUELMOTO
23Seven
Jun 21, 2019 01:37 AM
daytonhd
Jul 10, 2012 08:15 PM
hydrolock43
Mar 28, 2011 09:12 PM
jpalm
Nov 19, 2010 10:40 AM
tbone22
Mar 5, 2007 07:47 PM
