So, did you guys go with new cams without the addition of larger bore assemblys....I too have toyed with the idea or re-caming with my stock jugs and pistons.....and have wondered what advantages and disadvantages there are to this mod. Mine is an 06 Ultra w/ stage 1 mods, what is the cost for this gear drive cam setup? how does it effect the performance and fuel consumption? Thanks for any info you can pass along.....
I have Fueling pump,spring,Andrews 26 cams, gear drive, stock cam plate.stock lifters, SE tapered push rods. Stock bore 88 & SERT. MIleage about 37-39. Wife and I most of the time w/fill gear. Highway riding. it goes down. I still don't like the download I've got. too rich on low end. I'm still looking for suggestions on which map I need.
