Auxillary lights installed
Old Apr 17, 2008 | 06:14 PM
Puggy's Avatar
Puggy
Default Auxillary lights installed
Finally got the bracket's and lights delivered today and got them installed. Some assymbly required is an understatement (along with disassymbly, lol).
The only question I have now is how to adjust the up/down. One of them is pointing down a little too much.
Old Apr 17, 2008 | 06:23 PM
jahays32's Avatar
jahays32
Default RE: Auxillary lights installed
I don't think mine adjust up and down but I have an Ultra. My Suzuki C90 did not adjust enough and they had a bolt so dealer said just grab it and pull back on it. I thought yea righ, but with no other option I did it and damn he was right it worked like a charm. Of course its your call.
Old Apr 17, 2008 | 08:33 PM
snip0721's Avatar
snip0721
remove the bolts that secure turn signal. let hang. 9/16 deep socket with a 1" slot cut down the side. slot allows the wires to pass through without disconnecting. made mine out of some old off brand socket. looks like a 02 sensor socket.
Old Apr 17, 2008 | 09:03 PM
One Black FLHXI's Avatar
One Black FLHXI
Puggy, Just put a set on my Streetglide last week. If you assembled them per the instructions with the rubber washer on top, the 1/2 ball washer on the bottom and torqued the nut to the spec. You should not have to wrench on anything.Just grab the light with both hands and push it the direction you want it to go. I wondered too on how to adjust them. But, they moved quite easily. I positioned them according to the service manual. (25 feet and referenced to the high beam) Keep the rubber side down.
Old Apr 17, 2008 | 09:09 PM
Puggy's Avatar
Puggy
That's what I was thinking, but just wanted to make sure I wasn't missing anything. Thanks.
oldmanwayne
Sep 14, 2015 12:04 PM
hpyplc
2014-2024 Touring Models
Nov 30, 2014 10:54 AM
cpmman
Aug 9, 2013 01:06 PM
2010 Raffel Road King
Apr 12, 2011 11:31 AM
oley55
Jan 23, 2009 07:42 PM
