tighten driving lights
Old Sep 13, 2015 | 05:02 PM
oldmanwayne's Avatar
oldmanwayne
Default tighten driving lights
Is there a way to tighten a driving/passing light without disassembling the whole assembly. It looks like a split socket would work but I have no idea where to buy one..thanks
Old Sep 13, 2015 | 05:04 PM
Uncle Larry's Avatar
Uncle Larry
Make a socket by cutting a groove in a deep 9/16 socket to accommodate the wire. Sometimes you can "muscle" the lamps. Use care.
Old Sep 13, 2015 | 05:05 PM
mkguitar's Avatar
mkguitar
old posts will have pics of sockets with grooves dremeled into them...I've been using the same one for over 20 years
Mike
Old Sep 13, 2015 | 05:09 PM
oldmanwayne
Great. Thought that might work. I have lots of spare extra deep sockets that I can modify. I assume that this is how you would adjust them as well although it doesn't seem like there is much adjustment available. Again, thanks
Old Sep 13, 2015 | 06:50 PM
Ragtop's Avatar
Ragtop
If they are tight already, you can still adjust them by hand.
There is usually enough play left to tweak them by hand, give it a try.
Old Sep 14, 2015 | 12:04 PM
grbrown's Avatar
grbrown
An alternative may be to cut a slot in a deep throw ring wrench you can afford to sacrifice. I have one somewhere.....
chelomiami
Oct 10, 2016 04:56 PM
hpyplc
2014-2024 Touring Models
Nov 30, 2014 10:54 AM
just plain john
Jul 9, 2013 03:04 PM
oley55
Jan 23, 2009 07:42 PM
alqaadir
Aug 26, 2008 01:30 PM
