EFI and elevation changes
Old Apr 17, 2008 | 07:51 PM
choochoo's Avatar
choochoo
Default RE: EFI and elevation changes
The MAP sensor is what determines outside barometric pressure (elevation and cold heavy
dense cool air vs hot dry summer air). (this is a simpified explanation)
It compares outside air with what is happening in the manifold.
Thus determining (with other sensors) idle, cruise no load,
cruise pulling up a hill, WOT.
It makes the initial computation decision of amount of fuel needed.
The O2 sensors is an after the fact decision. If the fuel was originally too
rich or too leanthey further refines the process.
How the PCiii will act don't know.
But either way you'll be ok. Perofrmance and mileage may suffer somewhat,
but should be enough that you would notice it.
Old Apr 17, 2008 | 08:15 PM
scaires as hell's Avatar
scaires as hell
I have on 07 ultra with stage 1 down load. Runs on the lean side but when I ride at 2000 ft.or higher I get 4 MPH better
millage even going up and downin the moutains. Never pings and runs great!
Ride On !!!
Old Apr 18, 2008 | 01:53 PM
royalwulff's Avatar
royalwulff
Thanks guys, I was worried because the O2 sensors are disabled with the PC III, but it sounds like I am okay either way.
Old Apr 18, 2008 | 01:57 PM
GasCan's Avatar
GasCan
Ilive at the foot of the Rockies in Alberta which is 3500' above sea level and run the rockies almost every other weekend up to 9000' and not a single issue. I am running a Tmax on an 07 bike though.
Old Apr 18, 2008 | 02:08 PM
HEMSPLT's Avatar
HEMSPLT
02 Ultra with ECM flash and SE 95" stage II. Have been to the top of Pikes Peak (14,110') and several times up to 10,000 feet with no problems at all. Fuel injection compenates just fine. Don't know about PC III.
Old Apr 18, 2008 | 02:28 PM
mikes300's Avatar
mikes300
thats what FI is all about it changes for you based on altitude and temp, dosent matter where you tuned it at. if it was a carb your buddy would be right.
Mike
Old Apr 18, 2008 | 02:40 PM
myglide's Avatar
myglide
Your bike should be fine. higher altitude = richer. Less oxygen to fuel sea level = leaner more oxygen to fuel
Old Jul 5, 2020 | 01:16 PM
BlackBetty2010RK's Avatar
BlackBetty2010RK
Stage I
Default Elevation issues
Originally Posted by royalwulff
This is probably a stupid question, but I am planning a trip to the Rockies and one of my buddies keeps telling me that I will have issues with my engine pingingsince my tune was done at (roughly) sea level. I have a PC III, and always thought the PC III adjusted the amount of fuel depending on the air density sothe air fuel mixture was constant regardless of elevation.Am I wrong? Help me out guys!
I just took a trip to the Rockies and my bike has a stage 3 tuned at 650 feet and at 6500 I started having issues. 8500+ it was really struggling and I had to keep RPMs very high. Also looking for a solution
Old Jul 5, 2020 | 02:48 PM
NorthWestern's Avatar
NorthWestern
The only solution for that would be a turbo charger.
We all struggle with the lack of o2 on a NA engine.
Damn, this is an old thread!
flyer91
Aug 12, 2010 11:08 AM
Comingapart
Exhaust System Topics
Jul 14, 2010 10:50 AM
TGrahamVA
Jul 19, 2007 11:25 AM
hotammo
Jun 3, 2007 05:37 PM
DynaMike57
Mar 7, 2007 01:16 PM
