EFI and elevation changes
Old Apr 17, 2008 | 06:32 PM
royalwulff's Avatar
royalwulff
Default EFI and elevation changes
This is probably a stupid question, but I am planning a trip to the Rockies and one of my buddies keeps telling me that I will have issues with my engine pingingsince my tune was done at (roughly) sea level. I have a PC III, and always thought the PC III adjusted the amount of fuel depending on the air density sothe air fuel mixture was constant regardless of elevation.Am I wrong? Help me out guys!
Old Apr 17, 2008 | 06:37 PM
jag1886's Avatar
jag1886
Default RE: EFI and elevation changes
You have an 07 with OXY sniffers you shouldn't have any problems at all.The computer should be able to handle that.
Old Apr 17, 2008 | 06:41 PM
gene01's Avatar
gene01
the pc3, would be the problem, it eliminates the o2 sensors that would tell the computer what to change...
Old Apr 17, 2008 | 06:42 PM
1Harleyrdr's Avatar
1Harleyrdr
It will be fine!
Old Apr 17, 2008 | 06:45 PM
tombeving's Avatar
tombeving
I rode the Rockies in Colorado and British Columbia with my 05 Ultra and had no problems. At 9000 ft. you lose a little power and burn through gas.
Old Apr 17, 2008 | 06:59 PM
sbbrown's Avatar
sbbrown
I live at 8800 feet and ride passes that are over 10000 without any problems
Old Apr 17, 2008 | 07:09 PM
Windup08's Avatar
Windup08
Its the change in elevation that makes they difference, not high elevation in and of itself. Generally when you go up in elevation you run richer....less air, same amount of fuel means richer running. Its harder on a bike tuned for high elevation going to low than the other way around. EFI does a pretty good job of adjusting, so it isn't near the problem as with a carbed bike. I live at 6,200 feet, but frequently travel to MN and ND with elevations at or near sea level....my older carbed bikes would run real hot, but dang, I sure would get good gas milage on those trips. For the duration of a trip you aren't going to hurt anything....you will loose power at high elevation, may just have to run higher rpm before shifting, but again shouldn't hurt anything.
Old Apr 17, 2008 | 07:14 PM
Northside's Avatar
Northside
ORIGINAL: royalwulff
Your buddy is wrong. Your bike might run rich since the air is less dense at altitude. It'll run cooler but work a little harder.I always ran a little more advance on spark for the altitude on older bikes, no pinging. I live in Colorado and have ridden a few passes on both injected and a lot of carbed bikes. You lose a lot of power on the passes but so does everything else. You'll still be able to fly around motorhomes and semis. I've gone from 12,000 ft. to sea level with nary a problem.
Enjoy your trip!
Old Apr 17, 2008 | 07:18 PM
pop1's Avatar
pop1
Your bike will run fine but your ears will pop.
Old Apr 17, 2008 | 07:19 PM
rockdoc's Avatar
rockdoc
I live at 500 ft and my dealer is at sea level (where they tuned my bikes). Current bike is new and have not been able to get into the mountains yet (way too much snow) but my previous bike was a Dyna and had a PCIII on it. I regularly went from sea level to about 6000 feet fairly regularly and had no problems. Your bike will do fine on your ride.
