Black fork slider install...
Old Apr 17, 2008 | 09:37 PM
nowski91381's Avatar
nowski91381
Default Black fork slider install...
Bought the black upper and lower fork sliders for my 07 Street Glide and was just wondering how difficult the install was? What all do you have to do to get them on? Any info you could give would be greatly appreciated...thanks!
Old Apr 17, 2008 | 11:48 PM
vibr8ir's Avatar
vibr8ir
Default RE: Black fork slider install...
I removed mine and had a buddy do the guts..the only pain was getting the top fork nut off.You need a real thin wrench/tool to remove it so you can slide the tube down. put a better oil maybe diff weight to help w/ the mushy f-end too.. Oh don't forget to put the rubber d-nuts on when you slide the tubes back up..
Don't need to tell you how I know.. Your bikes gonna look great go for it. Remove tire,calipers,(hang w/ wire off Engine guard),fender. ing, lock, lower dash, loosen pinch bolts, then cuss and swear and remove upper fork nut(don't let it fork fall down) I think you need a special tool to remove the cartridge fork..
Why is only 1 fork cartridge type ?? Mines an 02 flht but I think its the same.. You need to bemd over the tabs on the fender bolts to remove them
Good luck ride safe Steve
Old Apr 18, 2008 | 02:53 AM
paconick's Avatar
paconick
this may help... FROM Do It Yourself forum index http://groups.msn.com/toddsharleypix...eforkswap.msnw
rs87277
Jul 12, 2012 12:38 AM
freewill
Sep 14, 2011 11:50 AM
jtbredneck351
May 8, 2010 11:59 AM
jefnightrain
Feb 14, 2010 08:42 PM
hell hound
Jan 16, 2010 04:35 PM
