1st 95" build ??
While apart is there any mods. I should do(sorry no head work now). I'm going to take out the adj. push rods. I'll install the burly bros. clutch arm and a new teflon cable.. I have a shop manuel, but my SE pistons have no instructions, do I need them ?? I'm going to have my barrels bored Tues, @ $170 seems fair to me ??..Thanks in advance I'm sure glad all you guy's/gals are here to help if I need it. The local shop Custom Design Studios had a open house last night and they unvailed the new Geico Ins. bike they built,,I'll try to get some pics up..Awsome build.. Ride safe Steve
Part number is C9844.
[align=center] Gasket Kits [/align][/align] DescriptionStock CodeOEMYearPkg QtyPrice All Twin Cam Motors Std. Bore w/ Hat Style Valve Stem SealC914617052-99B03-07Kit$102.08 All Twin Cam Motors 1550cc Big Bore Kit w/ Hat Style Valve Stem SealC9147
03-07Kit$102.08
All Twin Cam Motors 1550cc Big Bore Kit w/ .030" Head Gasket & Hat Style Valve Seal C9147-03003-07Kit$102.08 All Twin Cam Motors Std Bore w/ .040" Head GasketC9779
99-UpKit$126.10 All Twin Cam Motors Std. Bore w/ .030" Head GasketC9845
99-UpKit$102.08 All Twin Cam Motors 1550cc Big Bore Kit w/ .051" Head GasketC9951-051
99-02Kit$102.08 All Twin Cam Motors 1550cc Big Bore Kit w/ .045" Head GasketC9951
99-UpKit$102.08 All Twin Cam Motors 1550cc Big Bore Kit w/ .040" Head GasketC9780
99-UpKit$124.33 All Twin Cam Motors 1550cc Big Bore Kit w/ .030" Head GasketC9844
99-UpKit$102.08 All Twin Cam Motors "FATSO" Top EndC9789
99-UpKit$102.08 4.00" Bore Twin Cam Motors .040" Head Gasket & .020" BaseC9949
99-UpKit$104.47 4 - 1/8" Bore Twin Cam Motors .040" Head Gasket & .020" BaseC9976
99-UpKit$102.08 [/align][/align][/align] Š 2007 Cometic Gasket, Inc., USA. All Rights Reserved. | Terms & Conditions
Web Development by Malachi Computer Consultants & Saberware Computer Consultants
Steve
MaineUltraClassic thanks for the gasket #'s I'm ordering it tonite. I'll use the c9844 too as I have an 02"
If I need help I'll be back. thanks I'll Let you all know how I do.. Steve
Back to work Steve
PappaTravis if your using a bolt in type cam 510 lift you can user your stock p-rods. No need for ez inst. rods, I'm taking my adjs. out when I do the build to put the more realiable stockers back in. Now your $160 ahead get that build done.
Back to work Steve
As far as the tools for the inner bearing, I was lucky to find a forum member that let me borrow his. But, you can rent a blind spot puller from autozone, which will do the trick.
I use Cometic top-end gasket kits with the .030 head gasket.........you can get them from Zanotti's for like $85 delivered.
[align=center]Gasket Kits [/align][/align]DescriptionStock CodeOEMYearPkg QtyPrice All Twin Cam Motors Std. Bore w/ Hat Style Valve Stem SealC914617052-99B03-07Kit$102.08 All Twin Cam Motors 1550cc Big Bore Kit w/ Hat Style Valve Stem SealC9147
03-07Kit$102.08
99-UpKit$102.08
[/align][/align][/align]Š 2007 Cometic Gasket, Inc., USA. All Rights Reserved. | Terms & Conditions
Steve
and then you'll have no regrets, hell you have the parts. Did I read you were a Dice Man somewhere ??? Steve
PappaTravis callin it a night, I got down to the rocker boxes' .tomorrow I,ll tear it the rest of the way.. We'll probably have to call?? I'll see what my indy. can do cause I can't wait too long they're East coast I'm West (CA)..I'll look it up on their site and see if those #'s look good. I don't know if I'd use water on the pistons and cylinder bore a splash while cleaning the outsides o.k. .. if they look good wipe down a little oil and run it.. Do your build all at once, save money
And yeah, I deal dice. I work at an Indian Casino in NM. Been at it for about 5 years now. It's an ok job, and the money is decent, for here. If you can handle the smoke, which is the worst part of it. I am starting to have some issues with my back, so I just took a dual rate position, which means that I will be trading off between dealing, and sitting box... flooring. I tried to hold off on the flooring position as long as possible, but with me being 300 pounds, the muscles in my back are in a constant state spasms...
Keep me up on the build, and I will do the same, if I ever get started...
PN 0934-0762
For 99-06 Twin Cam w/ 95â big bore kit and .030â head gaskets
$102.95(Cometic) I am going to email Zanotti's now, to see what the price will be for it. Might just call tomorrow, as well, but I am up now, so I will drop a email.
